Rb25det Engine And Gear Box Into R32 Gts
Yeah so physically that port is consult not OBD2, but also be aware that "JODB" is not really a thing - it came in around 2000(ish) but is not a standard like ODB is, each manufacturer had differences. If you are looking at ECU only and have a standard ECU, go with Datascan as Turbo Tapin said. Per another recent discussion here thought that won't do other systems like in a modern car, for example bleeding ABS
They're not rebuilt Racepace items. They were mint. From memory the were ex display stock that I bought off yahoo and he ran....from memory he barely used the REs when he replaced them with a set of Tein RS If have been stored correctly and not leaked fluid then they will be mint As an observation the Racebuilt rebuilt Tein RA/RE/RS were a better street/club/track package. Really nice on the street and did good numbers at the track. I think the factory Teins wont match the Racepace valving on the street but would be in the same window of performance on the track... albeit firmer
The one time that Clippy is actually useful!
Paper clip method to read codes also works.
It's a 14pin Consult connector. You can use software like Nissan Datascan (NDS 1) to connect.
