About a week after changing to the rb25 turbo, my clutch hasnt been too happy, for a few reasons. I guess the extra power has worn the clutch, and it had run out of adjustment, which resulted in no fre-play and has effectivly rooted the clutch. Ive found out that the gearbox whine is only the thrust? bearing because of no freplay, but im going to have to buy a new clutch.
Im after a clutch that i dont need to go on steroids to use, but wont need upgrading when i go for my proper turbo/ecu upgrade. What do you guys recommend, and how much would i be looking for the clutch, and how much extra would it cost to install?
Im guessing that the stronger the clutch, the more bighty it gets, so i know i wont get the best of both worlds. Im in brisbane, so where can be recommended up here?
https://www.sau.com.au/forums/topic/21383-clutch-for-250rwkw/
I am going to be honest with you luke,
I have driven a R33 with a twin plate setup, and a R33 with a strong single. (with the same power output as yourself). Personaly i would take the single in this situation for 3 reasons:
1. Cheaper. (for a really good single your looking at around the $700 mark)
2. Doesnt rattle around like a 1986 VL taxi.
3. It will suit your power application perfectly.
if you would like the best of both worlds: (play & grip) i would recommend getting a cushioned ceramic button clutch:
http://www.horsepowerinabox.com/mall/ck06.asp
take a look, they deliver anywhere.
Cheers,
Trev.
Go the twin plate.
I bought a 9 button ceramic-ferride Xtreme clutch when I toasted my stocky. It was ok for a while, but started protesting after about 6 months - this is with only just over 200rwkw.
I then got a twin plate, the clutch I would have got in the first place had I the funds at the time. Much better, and I know it will hold even when/if I do the 3L conversion I have planned (if the RB25 dies).
A single plate clutch that can handle 250 rwkw will be grippy as hell - therefore you will shudder every single time you take off in first, even worse when you are taking off on a hill.
I know this because I have one. Next clutch I get will be twin plate.
matlowth (on this forum) is running a full faced organic single plate clutch. also producing over 300RWKW on a RB30/25. and drives it to work.
proof is in the pudding.
listen if youve got the dosh get the twin, if your scrap for cash grab a good single.
Probably best to buy direct from Japan, will save you some dosh. I got mine 2nd-hand and had it rebuilt:D I had a Nismo 5-puck clutch in my car, only last a few months and was a prick to drive. I'm much happier with the drivability of the twin-plate:D
You get what you pay for. There are single-plate clutches that will handle that sort of power, but they won't be as consistent as a twin-plate. I used an OS Giken twin plate in my R34 with 280-295kW at the wheels. It could handle any kind of abuse and still behave almost like a normal clutch in traffic.
Thanks for the reply.
I just noticed I put the wrong turbo on the post.
I am acutally doing a very similar build with a HKS 3037S so I think thats why I put the wrong one down (edited:)).
Congrats on the time - into the 11s with street tyres awesome!
Also good to see someone sticking with stock internals and making such good power. Seems so many people here dont think it can be done safely, when all they need to do is look to the birthplace of the skyline.
My head gasket and cams arrive on friday:)
Once again welcome to the forums, good to see you here.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
