in need of cash so thought id sell a few things ive got floating around.... do not want to post incase damage occurs would prefer pickup = reason for low price
Item:Large front mount intercooler 300x600x115 (VERY LARGE)
Age:unsure
Condition:brand new
Price:$350 FIRM
To Fit: (What car) ANY. mounting points to suit r32-33-34 GTR but can be made to fit anything
Contact: via pm
Comments:
Item:mines ecu
Age:unsure
Condition:good
Price:$200 FIRM
To Fit: (What car) r32 GTR skyline
Contact:via pm
Comments: selling because i bough apexi power fc
Item:braided brake lines
Age:unsure
Condition:good
Price:$75 negotiable
To Fit: (What car) bnr32, may fit others
Contact:via pm
Comments: taken off my car during compliance
will sell all 3 together for $500
(edit) just added 2 rc cars to the list a big chunky offroader 4wd single speed and an r34 gtr chell on a 4wd 2 speed racer(does approx 95 km/h) both are near new with only doing approx 4 hours each.. retail $950 each selling for $350 each.
also turbosmart blow off valve mount for r32gtst maybe 33 and gfb blowoffvalve(needs new spring) both brand new $60 for both
Edited by jenkies
Age:unsure
Condition:brand new
Price:$350 FIRM
Contact: via pm
Comments:
Item:mines ecu
Age:unsure
Condition:good
Price:$200 FIRM
Contact:via pm
Age:unsure
Condition:good
Contact:via pm
If the front mount is a straight bolt up i'll take it, thanks.
not too sure.... i bought it off a sau member a few months ago.... came in a blank box and there arent any markings on it.... bracket mounts and end tanks are to suit gtr.... its a little thick for the sort of power im puting out
c'mon make me an offer.. im even down for trades of interest.... after dump pipes and/or front pipe... or anything else
heya if u just chuck the braided lines in a box and send it to sydney i'll take em. i know u sed pickup only but make an exception?..pweeezzz!!!!
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
