  • Replies 52
yes s3 gtr xenon headlights fit BUT IT is no easy job and they dont just bolt on.
i bought a set and put them on my car, it took me along time to get them to fit correctly, as you need to trim alot of the headlight and ballast mount. and because you trim the mounts also there is nothing holding the headlight in place unless you make mounts and secure them.
Also the plugs are different so you can cut up the gtr ones or chop them off and put the gts-t on them.
stock s1 gts-t grill also doesn't fit correctly.
its far from an easy job and when you have to trim/cut up headlights which are worth more than $2000 each from nissan it does hurt
dont ask me whose car this is. i dont know. he's on here tho. tuffest front on a r33 i've seen tho
post-30915-1207725884_thumb.jpgpost-30915-1207725816_thumb.jpgpost-30915-1207725770_thumb.jpg
Im in love :( Thats the same frount bar and side mirrors as myn lol now iv just gotta find them and see what i can do and if i can keep it legal
Would this mean gtr lights on a gts-t are iilegal? i was thinking if i did the angel lights using my sr1 base and frount lense i could maybe engineer them.
Not sure if that sounds stupid but i really like thoses lights
those headlights are illegal because the globes are no case in anything. if you do a retro fit to your s1 headlights then it will be fine.
there is a place in japan that can covert s3 gtr headlights to angle eyes i see if i can find the link (the price is around $300)
"there is a place in japan that can covert s3 gtr headlights to angle eyes i see if i can find the link (the price is around $300)"
$300 ?? does that mean you send them your lights and they modify them? I think they look wicked.
"dont ask me whose car this is. i dont know. he's on here tho.
Reduced 91%"
If i did this to my car but made a fiberglass moulding for it, would it pass or would i need a clear lense in front too??
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
