  • Replies 52
yes s3 gtr xenon headlights fit BUT IT is no easy job and they dont just bolt on.
i bought a set and put them on my car, it took me along time to get them to fit correctly, as you need to trim alot of the headlight and ballast mount. and because you trim the mounts also there is nothing holding the headlight in place unless you make mounts and secure them.
Also the plugs are different so you can cut up the gtr ones or chop them off and put the gts-t on them.
stock s1 gts-t grill also doesn't fit correctly.
its far from an easy job and when you have to trim/cut up headlights which are worth more than $2000 each from nissan it does hurt
dont ask me whose car this is. i dont know. he's on here tho. tuffest front on a r33 i've seen tho
post-30915-1207725884_thumb.jpgpost-30915-1207725816_thumb.jpgpost-30915-1207725770_thumb.jpg
Im in love :( Thats the same frount bar and side mirrors as myn lol now iv just gotta find them and see what i can do and if i can keep it legal
Would this mean gtr lights on a gts-t are iilegal? i was thinking if i did the angel lights using my sr1 base and frount lense i could maybe engineer them.
Not sure if that sounds stupid but i really like thoses lights
those headlights are illegal because the globes are no case in anything. if you do a retro fit to your s1 headlights then it will be fine.
there is a place in japan that can covert s3 gtr headlights to angle eyes i see if i can find the link (the price is around $300)
"there is a place in japan that can covert s3 gtr headlights to angle eyes i see if i can find the link (the price is around $300)"
$300 ?? does that mean you send them your lights and they modify them? I think they look wicked.
"dont ask me whose car this is. i dont know. he's on here tho.
Reduced 91%"
If i did this to my car but made a fiberglass moulding for it, would it pass or would i need a clear lense in front too??
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
