just need some help with this, i have all the supporting mods and want to make around the 260rwkw.
almost at tune stage but need to know whether or not i need to buy bigger injectors or whether i can just put a fuel pressure reg on it and bump up the pressure.
i have an ignition DVD with a hybrid 25/30 in it making 280rwkw on standard injectors, how is this done, i thought they max out at around 220-230???
also if i do have to put injectors in it, will i also need to put a reg on it??
cheers in advance
injectors. when u put in a adj fpr, u are moving curves that aren't usually moved. making the whole tuning process a lot more difficult.
just go injectors and a decent management system.
dont cheap out on it.
Edited by r33cruiser
hey SL1D1N, I in no way mean to hijack your thread, I am in a similar position (should have similar power by this weekend) then will need a tune and fuel system upgrade, and I was going to ask a similar question as you,thought it might just be able to be answered here instead of opening up a new thread....
So to upgrade the fuel system, you don't need to get a FPR if you get new injectors and pump? and does that mean a fpr just uses your current injectors to spray out more then what they are meant to? wot about your fuel filter when upgrading?
Thanks mate, Adam
BTW good luck with the tune!
Using a FPR to increase the pressure to get more head room out of your maxed out injectors is a short cut. If you are going to chase bigger numbers down the track you are going to eventually need bigger injector anyway so you may as well get them in the first place.
Yep, s15 sr20 480cc side feeds, or any of the 550cc ones are fine for up to 300rwkw(or 350 for the 550's) Upgrade the pump and keep the stock reg. What management are you guys running.
Awsum, thanks for that. I thought my mate was full of cr*p when he said I need fuel pump,injectors AND a fpr...
I have a powerfc and commander :)
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
