Hi all , trying to see if anyones interested in a coffee meet + some dinner etc and a small cruise towards west end for some pics
Coffee location would be logan road Mt gravatt Coffee club the usual spot meet up time around 7-7.30pm ( near Red Rooster and Austral (southside Land Rover)
Post up who is interested ... i will post more details towards end of next week ( i.e activites etc)
-Meet for coffee then cruise out to west end for some pics cruise through the city and head off
Cheers
Vish
Edited by 53XYN
https://www.sau.com.au/forums/topic/214229-coffee-chai-meet/
  • Replies 56
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
