Hi,
In attempting to track a trajectory on a map in Nissan datascan's "Map Trace" function, the TPS gets stuck on the minimum value. I recall that if U know the address of the TPS value, U can get this to work on any RB, SR, etc. My application is an RB20DET, stock CPU. Anyone know where the value is hiding? Also, any hints on how to extend the selection of available maps would be great.
https://www.sau.com.au/forums/topic/214246-tps-value-address/
Thanks for rply,
Take a look at
inhibit_harvest_url_ttp://202.43.224.130/
with the "inhibit_harvest_url_" bit replaced by "h" of course.
point 10.
10. Map trace
  • A real time trace of a position on the map. This function is only available for z32 300zx cars at the moment. If the real time TP value address is known the function can be set up to work on any Consult I Nissan car.
The TP address is the spot in RAM in the ECU where the CPU stashes the TP (throttle pos). In datasacn, you can tell the map trace function this address. Then the map trace function can get its grubbies on the TP. Next U watch the track of the trottle/rpm curve pass over the timing and fuel map as you wind the car up. When you get ot a place you dont like the feel of, or it leans out or pings, you can tweak the map there :D That's assuming you know how to down & upload the maps. That leads to my second question. Does anone know how to give datascan more (read my custom) maps? That way, I could read my values off the display instead of having to look them up in a seperate app.
Further to that, it just occurred to me that the real time TP address might also be a memory mapped I/O register that the CPU reads to get the TP. Either way, it gives access to the TP for this particular datascan option.
TP memory addresses for VG30DETT, RB20DET and SR20DET identified by current NDS users are already pre-programmed.
get the latest version if you're using an old one - there is an option on dropdown for rb20det?
i think thats the point of it - they will read the maps from the rom and then display your position on it. because from memory once you choose your values it will then populate the table (fairly slowly, so presumably this point its reading from the map) before it starts showing you the trace
Yes, this is the way my old version works. I can't imagine that that would change, but U never know....
Shame we have to pay for the new one (hence all the questions), but it's not much.
Now, let's pop that rom out, solder in the piggyback, wire it up and were away....
No more soot on the boot...... :laugh:
Have you looked into nistune?
Intended to get something like a type 2 board, but no s/w.
Also will look into PC BIOS backup/switch boards & software. These ECU eprom sockets are obsolete,
and I expect there is junk out there for nothin'
Plenty of time.... It's a slug & I'm old, and patient.....
  • 1 month later...
Hi,
So can this be done on and rb25det also?
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
