I drove from Bathurst to Sydney this morning, and after a while I started to notice (hear and feel) a vibration resonating from what I'm pretty sure is the gearbox area. I tried accelerating in a few different gears past 80km/h and the shudder was the same for all, so I determined it isn't a gearbox problem. the engine still revs fine up to 7000rpm so it's not an engine problem. the shudders aren't coming through the steering wheel as such, more the entire car is shuddering, so it's not a steering alignment/balance problem. It picks up a resonance of around 1-2Hz as I'm driving over 80km/h, but it comes and goes, usually for about half an hour at a time. The vibrations are constant however.
My theory is either a Uni-joint on the tail shaft, or a bearing somewhere in the gearbox/tailshaft region. I'm not an expert on the mechanics down there so it's just speculation.
My question now is has anyone experienced a uni-joint or tail shaft problem before? this is a first for me as neither of my previous cars have had the problem. If I'm right and it's a uni-joint, how hard/expensive are they to replace? I'm trying to sell the car, I don't need an expensive repair job right now.
If anyone has some guidance for me let me know, otherwise i'll have to see a transmission mechanic to help me out.
Cheers,
Leshy
https://www.sau.com.au/forums/topic/214256-good-vibrations/
  • Replies 50
It does sound like a uni joint. :blink:
I've had one fail ever so slightly and it is definitely felt in the body of the car. Fixing them is simple enough if you wanna give it a go yourself.
Remove the circlip and use a flat head screw driver and hammer to tap them out. A suitable mechanic should be able to replace them cheap enough.
Also, if your tailshaft is out of balance, this will cause the problem also. But the weights to balance it are usually welded on, so its rare.
Edited by RubyRS4
https://www.sau.com.au/forums/topic/214256-good-vibrations/#findComment-3783725
Not good dude! It might be a uni, but in my experience if the uni is failing there is usually a tapping or knocking sound associated with the vibration due to the bearing surfaces in the uni constantly coming in and out of contact with each other. I know tailshaft balance problems are rare, but I would be looking closely at the rear tailshaft anyway to make sure there are no shiny patches where weights may have dropped off.
Yours is a manual, isn't it? How was the clutch surface of your flywheel when it was installed?, but you will know if this is the problem because the clutch will start to slip.
Also have a close look at your wheels (esp the front ones) to make sure there is no balancing weights that have gone south.
Other than that, all I can think of is the dreaded ATESSA system problems (maybe chain drive to the transfer case?)
https://www.sau.com.au/forums/topic/214256-good-vibrations/#findComment-3783834
yeah i don't think it's out of balance, hopefully just a uni joint. are they skyline / stagea specific, or just a generic uni joint off the shelf? I'll have a look when I get home on the weekend, see if there's much movement in the joints.
I've already blown one transfer case apart, i don't want to do it again. it's making very differnet noises to the time my transfer case kicked the bucket, so that's why i didn't think that initially. I had the flywheel machined flat when I had it all installed. The vibrations are intermitted, so perhaps it's only just starting to fail? theres a lot of vibration in the gearstick too.
https://www.sau.com.au/forums/topic/214256-good-vibrations/#findComment-3783838
Are you sure there is no noise? Cause when the uni in my front drive shaft went, the clacking noise drove me nearly batshit crazy.
The uni joint can fail ever so slightly that the tailshaft is slightly out of alignment horizontally, making it out of balance. Whereby you feel the vibrations, but no noise might be assoicated with it as the joint spins up with centrifigal forces. A bit like sitting in the Gravitron!
:blink:
https://www.sau.com.au/forums/topic/214256-good-vibrations/#findComment-3783887
yeah well it gets worse with speed rather than RPM, which ruled out the clutch. I know I need new front tyres and a wheel alignment/balance, but it shouldn't be vibrating the whole car. also the noise is coming from the gearstick hole. i'm glad i didn't seal the hole completely, else I might not have heard it at all.
I'd hate to go batshit crazy, i'll fix it asap!
https://www.sau.com.au/forums/topic/214256-good-vibrations/#findComment-3783943
Well my problem answered itself. I'm currently stuck on the side of the M4 near the cumberland highway with a front driveshaft hanging out of my car. cruising along at 90k's something suddenly went BANG then i lost my clutch and the engine died. the driveshaft was hanging off the front of the car like a rag doll.... this is the 2nd time my gearbox has kerploded on me, i don't know what i'm doing wrong, i had professional gearbox mechanics install it after it broke the first time.
anywho, i'll just become a resident of the M4 for the next hour or so until NRMA comes to pick me up I guess.... doh
it has to happen when I'm trying to sell the car doesn't it.
https://www.sau.com.au/forums/topic/214256-good-vibrations/#findComment-3785403
sh1t dude ! bad news ! I was hoping to get on here and say" check the tyres for bubbles " and you would be like ZOMG thats it - and I would be like - huzzah - hooray for boobies- and that sort of cary on .
maybe your gearbox / transfer case mounts are stuffed?
https://www.sau.com.au/forums/topic/214256-good-vibrations/#findComment-3785426
Damn, that sucks :( but at least you've found the problem :( big :thumbsup: that can be the worst part, not being able to find what the problem is...
lol you've got no car, you're stuck on the side of the M4, and you're still posting? :laugh:
Edited by DaveB
https://www.sau.com.au/forums/topic/214256-good-vibrations/#findComment-3785429
well when i initially put my gearbox in, the transfer case destroyed itself within a month. I got the whole thing replaced properly and now this happens after 6 months. I'll be talking to the workshop in question about a warranty on this, because there's no way I'm that unlucky to buy 2 lemon transfer cases
https://www.sau.com.au/forums/topic/214256-good-vibrations/#findComment-3785433
Oh man that sucks the big one! :thumbsup:
If its your driveshaft that blew, how recently was your gearbox fixed the first time? Try hitting up the mechanics for a repair. Was it bearing failure? Check the docket/invoice from you previous work to see what was involved. It might be covered.
Sorry, the only assistance I can give seeing I'm in Adelaide and you're on the side of the M4.
:laugh:
Added: can you get pics of the damage/break? Post 'em up
Edited by RubyRS4
https://www.sau.com.au/forums/topic/214256-good-vibrations/#findComment-3785434
Wireless Baby! I've got my work laptop with me and a NextG card
https://www.sau.com.au/forums/topic/214256-good-vibrations/#findComment-3785443
Um...maybe because the front shaft has taken out your clutch actuator :thumbsup:
When mine went, the uni had punched the bearing retainer almost al the way through, I was about 5km of driving away from what happened to you....
https://www.sau.com.au/forums/topic/214256-good-vibrations/#findComment-3785579
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
