  • Replies 50
Thought I'd give you all an update on my driveshaft kerplosion.
I have an R32 GTR drive shaft on it's way. I'm picking up an R32 GTR box that's blown tomorrow from Sydney, of which i'll be pulling the transfer case off which will bolt up to my current R33 gearbox.
The mechanic said my water pump is stuffed, and my timing belt needs replacing, so I'm getting that done at the same time.
And I've just received my big end bearing seal which I thought I'd replace since after 200,000km i'm sure most things need replacing, and I can only get to that seal with the gearbox off.
Fingers crossed, I'll have the car back on the road Wednesday next week, so only about a 2 week turnaround, all thanks to my helpful SAU community selling me spare parts.
Yeah it wasn't fun, especially since i was in peak hour traffic on the M4 in the right-most lane. luckily i had awesome NRMA coverage and they towed me back to Bathurst. I'm getting a new gearbox this weekend and should have the car back on the road mid next week.
damn
its always the way, selling the vehicle and it suddenly needs major repairs, thru no fault of your own
bad luck leshy
hope it sells soon, as its very tidy
just wondering if the kms are scaring off buyers? shouldnt......................
Yeah I think it is, but what can you do? I got good usage out of the car, i'm not selling it because it's got lots of km's on it, only because I need to move on to different (not better) things. The car runs fine, it's had a lot of work done to it, but it might just take some time to find the right buyer. No biggy for me, I'm happy to hang onto it until that time.
