  • 2 months later...
i was thinking about this myself but im a bit confused,teehee.gif....on a s13 when you turn up the heat for example or change the heats direction from say the window to the vents with the digital unit isnt all this done automaticaly in a s13 with motors?wear as in the cefiro its done manualy by hand.did you have to put in motors ect?or am i totaly wrong and confused hear?
i think your both wrong and confused, what is being said is once you pulg in a digital control on a non modified wiring plug you will blow a circuit effectively making the unit work as it did before( blow air etc ) except for when you modify the wiring to make it work something will be wrong with the unit.
from what i can see when you plug the unit into and unmodified loom it will do damage?anyway thats not what i was on abut my post was in refrence to the original poster off this tread and the fitting off this item correctly as im wanting to do this myself,in an s13 usuing the digital unit,isnt air directing,air tempetaure controlled automaticaly by motors opening and closeing vents behind the dash?in a cefiro isnt done manualy?i know some off the functions are done off a switch but like the hot/cold is turned up and down manualy by a leaver is it not?
No.
Cefiro air con looks like an analog piece of shit, but there is no levers / cables etc.
Cefiro stock air con is actually climate control.
Take it out of the dash and have a look.
And dunno wtf you smokers are on about :P Tested my unit twice against 2 different cars - works fine, still.
  • 2 months later...
  • 1 year later...
  • 4 weeks later...
K I think I got this figured out for the our cars but I rather just buy a harness from someone then re-pin one, dose anyone make one for me or know where I can get one??
  • 3 years later...
  • 7 years later...
For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc:
https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm
"Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it."
Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31.
I'm decent with wiring but feeling kinda lazy about taking this on.
Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx
"After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)."
Lol wtf
Edited by S1_C34
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
