hey everyone jsut started working on my r33 gts25t by putting on a greddy intake. how do you fix the throttle cable so it will reach nicely mine seems to be short. post up the fix if you would. im inthe US so parts are not that easy to come buy
thanks craig
https://www.sau.com.au/forums/topic/214767-greddy-intake-problems/
one more thing what did you do with the wires for idle sensor and that other one purple and brown plugs did you extend the wires so they would reach and thanks again my throttle works now the cable though is about 8 inches longer i had to loop it around down by the fuel filter and also had to modify the bracket like bend it alittle
I used a throttle cable from a Nissan Pintara....I just went to the motor wreckers with the R33 one and had a look at different Nissan cars...I matched up the accel pedal end...The end on the throttle body is clamped with a nut and bolt...The bolt has a hole drilled though it just under the head and goes through the pulley on the TB..the nut is tightened down onto the cable...
One thing with the throttle cable is make sure that the inner cable and out cable at the throttle body are on the same axis..ie make sure that the inner cable pulls out squarely. If is doesn't you will make your pedal heavy and wear out the cable quickly...Too me this seems obvious but I have seen many custom throttle linkages that are failures waiting to happen...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
