i have read and re-read my post and i never said they wouldn't fit but they would probably be undervalved (due to the weight difference). so the question of whether they would work acceptably is up for grabs.
aftermarket R33 shocks is a different ball game for valving hence you have obviously found something you are happy with.
getting back to what was posted, do you think standard shocks will work acceptably?
  • Replies 89
standard is unaccaptable to me
every car i get, within a week they are in the trash
so IMO, no, even on a stagea, standard shocks do not work acceptably
but you act like the remark was directed at you...it was directed to everyone who said they woudlnt work
they will work, maybe not parfet (if standard) but most wont be able to tell. I mean, most people dont know when a shock is blown
its al relative, most of you guys talk out of your ass, and on hypotheticals, while im sitting here DOING the stuff you say cant, or shouldnt be done. I dont have problems making apexes, i dont have problems in touge keeping up with other skylines and silvias. When you buy aftermarket suspensions, its stiffer than stock correct? stiffer than the gtr front suspension? YES I build my cars to handle, comfort is ALWAYS a sidenote to that. You cant have a fantastic handling car and be plush...its not possbile
so yeah, if you were putting stock for stock on the car MAYBE it would be an issue, but aftermarket coilovers (i would never buy anything otherwise) its not going to make a lick of difference to the average driver. And if it does, throw the fronts out to get revalved for 200 bucks and call it a day
quit reading your life away, and start doing.
:D 100%
I love proving people wrong, who say it can't be done!
If I listened to everyone, I would never have done half the things in my life that I've done. Nor built half the insane projects I have.
i'm glad we agree on the standard shocks not being suitable.
remind me not to stand near anyone when you are holding a shotgun. :)
but you guys said it wouldnt work
NOT that its undervalved (which i stated) or that they arent for a heavier car
you said it woudlnt work
So yes, i call you that disagree idiots.
I am here, telling you for a fact, not hearsay that it works. You want to know why? I HAVE THEM ON MY CAR. I have r33 shocks on my car. so who are you to tell me it doesnt work, when it obviously does.
Its like the deaf leading the blind.
Tell me then how you fit R33 rear strut tops with 115 mm bolt centres into a Stagea that has 80 mm bolt centres?
Im sure if sydneykid came in here and said they fit you would all bow down and kiss his feet.
That's because I am usually (but not always) right, it's called runs on the board.
Cheers
Gary
Cheers
Gary
obviously youd transfer your stock tophats to whatever you put them on.
i have stock tophats on my coilovers, no need for anything else.
the argument is if they woudl fit
so yes, they fit
Now, if his car was on blocks with no suspension, that would be different.
you know what
i bet you 1,000.00
that if you picked 5 random people, that dont do track time
and put them in my car
and put htem in a random car with overly expensive shocks with little collars that you move for height
you wont be able to tell the difference
Pick 5 Stagea people and I think you would be proven wrong. That's your problem, the average Stagea owner is more educated on what is good and what is bad than the average punter. Talk to your audience, on the Stagea thread don't treat the readers like idiots.
only diff is mine is stiffer, and handles super duper flat around turns
So it's slow then and lacks traction.
All that proves is they are doing worse than you, not that you are doing it right.
Wow, you better tell BMW and AMG and Porsche and Jaguar etc that they are doing the impossible.
So tell me, when you buy your V35 or M35 how are you going to use "coil overs" in the rear?
Because the people who really know are aware that "coil overs" is simply a description of the layout of the springs and shocks. That Skyline R32/33/34's and Stagea 34's come with coil overs standard.
Much fun for all
Cheers
Gary
so yes, they fit
So you admit that they don't fit.
But wait there's more............
What do you suggest they do when the standard Stagea rear spring seat is 75 mm and the coil spring in the coil over kit is 60 mm, or 62 mm or 65 mm or 70 mm? They are all common coil over sizes. They have to change the springs? Oh look, another reason why they don't fit.
Cheers
Gary
I have R33's in the rear of my S1 4wd Turbo.
iijj has driven it he and I seem to think it is fine.
ant
R33 what?
R33 rear shocks only? Yes they will fit and they will work OK for a while, as long as they are in good condition.
R33 Springs? Nope they won't fit, wrong dimensions
R33 Strut tops? They won't fit either, wrong stud pattern.
What we are talkibng about here is complete R33 shock/spring units and they definitely won't bolt straight in, for the reasons above.
Cheers
Gary
R33 what?
Cheers
Gary
Must be just the shocks only then.
Was that way when I got it... I noticed it a few weeks ago when I had them out... written on them in white marker.
Ok so I need to keep an eye on them as they wear... good to know.
ant
Cheers
Gary
incorrect
tophat has rubber cup base, if you insert it, and drive, the heat generated from the spring will seat it in its new position on the tophat
problem solved, i had the same problem
anything else?
R33 what?
Gary is right.
I just fitted Ohlins coilovers designed for an R33 setup into my S2 Stagea at all 4 corners. I had the rear hats removed and modified by an engineer to change the bolt pattern from 115mm to 80mm, and machine down the hat itself down to 115mm diameter maximum along the mounting bolts length (its actually machined oval shape).
Stag now feels mucho better!
:shrug:
some people worry about every little detail
some people spend half that time just doing it and makign stuff work and get to the track faster :P
im that guy
im using parts from 5 or 6 different cars on my car to make stuff work
I mean, it doesnt hurt that i have like a junkyard of parts at my house from my past track cars, but its not hard stuff that im doing.
Well FWIW, when the shocks get worn out in my RS4V (which probably isn't far away...), I'll simply fit a set of Nismo S-Tune's to suit. From memory the price quoted was ~$1500 for a complete set (inc springs).
They WILL fit, and should work a treat on the road.
:P
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
