Unfortunately my bulb is not a blue bulb. Its simply a normal bulb with the standard Nissan blue cover over it so that the light comes out more whiter than yellow. Its the stock standard bulb.
I think the LED one somehow is a straight fit plug into the wire connector. Must be aftermarket.
Damn its actually a wedge bulb type fitment for you?
The R34 GTT one is some weird looking bulb+base in one. I have attached a pic.
You should have no problems with changing it for led, looks the same like mine, its hard to pull them off
THIS IS A NORMAL BULB LIKE FOR DASH, I THINK ITS T10 or T5
Edited by naomy
have u ever fitted LEDs to your car before? because they are all like that.
you jsut have to pull the thing off.....and stick a LED in there.
but dont do it until someone confirms its actually a T10
Haha dude Ive fitted it MANY MANY times, aircon LCD, aircon buttons, dash, triple meter, cigarette lighter, everything except for the ignition.
You cant pull that bulb off the white base, trust me I tried, its not a wedge type design.
And the glass bulb is pretty small, T5 sized almost
Im pretty sure they are T5 or T10 wedges, at least mine arent.
and these are a Neo wedge bulbs for a/c
R34 has T5
i dont know how is it with r33 32
P.S. google it.
i bought yesterday for myself 12 so 9 can sell if anybody is interested......
post pics after install
Edited by naomy
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
