lcd leds or just a rear leds (button leds) ??
No I dont have but im pretty sure its somewhere on sau unless u talking bout lcd led
try this:
http://www.skylinesaustralia.com/forums/Co...l&hl=666dan
Edited by naomy
Damn its actually a wedge bulb type fitment for you?
The R34 GTT one is some weird looking bulb+base in one. I have attached a pic.
Haha dude Ive fitted it MANY MANY times, aircon LCD, aircon buttons, dash, triple meter, cigarette lighter, everything except for the ignition.
You cant pull that bulb off the white base, trust me I tried, its not a wedge type design.
And the glass bulb is pretty small, T5 sized almost
Im pretty sure they are T5 or T10 wedges, at least mine arent.
You're right nuffsaid.. it is a bulb in base design. So no wedge.
I had a look at mine, tried to pull it off to no avail. So what i did was smash the globe (harsh I know), and then wired the feet of the led directly onto the base. A bit of stuffing around I know. But it looks trick.
wish i took photos mate.. but i'll try to describe it as well as i can.
1. Following instructions in the first post, remove the steering column cover.
2. Twist to remove the bulb holder.
3. Using a pair of pliers remove/break the bulb.
4. Remove the bulb filament with the pliers, you should then see two holes.
5. Take your blue led bulb, and straighten the legs (two wires + & -) out on it.
6. Chop off the legs to make them shorter.
7. Reinsert. The Dan666 T5s supplied ones just fit the bulb holder, so once squeezed in they should be a really tight fit and unlikely to come out.
8. Test and then reassemble column cover.
Having said the above, I wouldn't really recommend doing it this way and a new wedge bulb holder type holder is definately the more reliable way to go.. so do the above at your own risk. Although it's just a led light, you do really end up destroying the bulb/holder in one thing by performing this mod.
  • 4 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
