Hi All. As I work on getting my new addition (R33) up to where I'd like..
Thought I would share some costs of things for comment and possible better bargains around the traps....but I am always about quality not price
(please excuse my very technical language. not)
Ozzy tyres $2k - four Koing "unknown" black n silver rims + Kuhmo (?) tyres
Audiotech - 300 ish for a "beauty Board" in the boot (to make the 2 amps stand vertical, hidden cables only seeing the face of the amps, in front of the battery etc)
Audiotech - 300 ish for a fibreglass side box for the 12" sub to sit on the side of the boot so I don't lose all that boot space
Unique Auto (syd) $130ish engine clean and detail
JAX tyres - 1499 for a set of 18" Speedy Black rims and "unknown tyres"
Tempe Tyres - 1500 for a set of 18" Lenso rims and "unknown tyres"
Mitchell Tune (Heavily Mod engine) 750+ (Ball park)
Fyshwick tune (Heavily Mod engine) 850 to 1k + (Ball park)
Interior trim - 2 quotes to come ( New dash due to previous owners display) + possible leather trim door options + possible coloured dash.
NewGel - $1800 ish to pull off, fix cracks and scrapes, re-spray all body kit components including new colour mesh over front mount then re-mount
Red LED Parkers 18
Phillips H1 Lights (cost anyone)
Skyline boot light - $300 Red
Brake spray - $15 to $30 Gold (haha..the paint to do your brake pads)
Momo Steering wheel re leather - Price unknown (It’s blue, I need it to be Black or Red)
Momo Leather gear boot - $60
Momo Leather Hand Brake cover $50
Momo racing pedals (set of 3) - $95
Momo floor matts $190
Momo racing harness (seat belts) x2 200 each.
Set of 3 - Apexi / Sabre / Stri Gauges - Can anyone recommend other brands, not to fussy
Edited by Cpt. Rock
https://www.sau.com.au/forums/topic/214983-fyi-the-cost-of-things/
I'm one of these research and evaluation freaks before I buy. So no nothing bought yet, only info after a few yarns.
why dont you shop for some second hand Volks of the forum, for around 2k you get some sweet wheels!! Ok, why Volks ? (Remember totaly new to this stuff :laugh: )
Ok Supafly - hit me up with a piccy of the wheels and details and we can rap..., same with you Towlie (is the term "PM me" ?) or should I jump over to the fore sale site. Thanx
Edited by Cpt. Rock
Rays Volks! cause there hot and they are very very well made, un like a lot of other rims that you will get from cheap places, volks can be repaired if they are buckled or chipped with ease. They are also light weight too. Who was the mitchel tune though... Trojan???
Edited by race_snooze
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
