  • Replies 56
i own a series 8 rx7
the car sure looks good, drives good.. when it drives
wat most ppl dont figure out b4 they buy one:
the reliability mods which MUST go on the car straight up
mazda just didnt build a mazda to last and used shit plastic crap in it
plastic AST (breather tank) will need to be switched to an aluminium one (if it leaks.. can kiss ur motor goodbye)
radiator is totally inadequate in stock form
exhaust is extremely restricitive, compliance will switch ur cat to one which is even worse than stock cat
solenoids tend to fail easily(break or crack in heat).. the twin turbo system is extremely complicated
ud need to do a compression test on ur motor b4 u buy it, anything less than above average/excellent.. ur motor wouldnt last too long .budget $5000 just for a rebuild minimum and about $1500 for upgraded apex seals.
to run any mods.. ud need an aftermarket ecu, PFC's are used quite alot.. dont use anything else.. they are junk..cept maybe motec. microteck, haltech, wolf watever are all junk
replacing IC is a fair job.. front mounts dont really work well on FD's.. they just look good. the best bet is a upgraded SMIC or a vmount..vmount will require u to get a vented bonnet
maintaning a fd is ALOT of $$$
my clutch line popped all of a sudden one time going across the harbor bridge..
my motor gave way after 1 month of ownership
security - fd's are getting stolen alot now.. make sure you have the best of alarms and full comp INSURANCE.. i learnt the hard way
ive owned my fd for 1 year exactly now.. its been off the road for 7months
if ur worried about fuel.. dont buy a fd
a stock fd would typically get u around 400km/450 max if u dont step on it per tank of 76L 98 octane.. if u are running aftermarket seals. ud most probably neeed to run pre-mix which is $35 for 1L...
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3803102
They are awesome. As soon as my car sells, i'll be buying a series 8 Type RS
As has been mentionened before, definatly look at the Type RS. More power, 17" wheels, Bilstein suspension, larger brakes, foglamps, 4.3 diff.
Get onto AusRotary and FD Owners forums and find out as much as you can about them. Also, check out this website Click here. When I started looking into them, I found this site to be a great source of info.
Good luck!
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3803304
series 8 Type RS?
how much are one of these.
the is saying he wants an RX7 until he can afford an R34 GTR. which seems to be under $50K these days via import.
he post by KIN seems to be what I've heard from my mates with rotaries.
One has a series 6.
the radiator issue was his cause for rebuild.
thw twin turbo's and their well known problem of cracking the rear housings caused him to get a bigger single.
the bigger turbo need for FMIC caused him to spend ALOT of money on cooling upgrades.
They are sweet looking cars.
no doubt about it.
and they go like shit off a shovel.
well balanced etc etc.
but man.. if you are going to buy one, spend extra and buy one already rebuilt with all the problems that KIN has posted, already fixed with receipts to prove it.
It's very much like buying an 89 GTR for $15K... you gotta have another $15K to sort it out once it pops.
and they all pop. unless you granny it. but who buys skylines or rx7's to granny?
Edited by GTST
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3803911
You're better off with a good low mileage original engine or one that has had a new OEM block. Other than that, look for one that has been rebuilt by someone respected - ask around (see link above).
In 100% stock form, they are great. With a series 8, the only thing you really should do is replace the air sep tank (AST) with an alloy version (you can buy one from JustJap for under $100, or spend a few extra on something 'JDM' brand name).
But who can leave a car like this stock?
Once you start adding things, then you have to consider the car as a whole - not piecemeal modding. Add an exhaust, add a PFC (for series 8 280ps version - not such an issue with lower power versions). Add an aftermarket IC, add an upgraded radiator.
They're not that difficult. Unfortunately, the average citizen of the world is a moron, so they are not for everyone. If you are willing to do a little research and do things patiently and properly (i.e. your first mod should not be an ebc), you will be hugely rewarded. Otherwise... buy a toyota.
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3804377
"budget $5000 just for a rebuild minimum and about $1500 for upgraded apex seals."
Thats not really too true, unless your talking about a rebuild with new turbo manifold/turbo/wastgate etc. My brother had his rebuilt and with aviation spec seals and it was less than $4,000 drive in drive out. My rebuild at SCR was 6-7k with heaps of upgrades.
"if u are running aftermarket seals. ud most probably neeed to run pre-mix which is $35 for 1L..."
Not true either...I had SCR steel race seals in my FC and it ran perfect on 98ron fuel, also my brothers FC with Aviation seals was the same. No need for crazy high octane fuels unless your running huge boost(18psi+), and you just dont need to do that to make big horsepower in a rotary anyway because they can handle bigger turbo's running lower boost whilst remaining responsive. My FC had a GT35R with 1.06 rear housing and it had less lag and was more responsive than the stock turbo....
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3804774
Is it possible to convert the sequential TT setup on the RX7 to parallel, as can be done to a Supra? That would be interesting :D
Common (most often suggested by workshops who can't troubleshoot the sequential - i.e. nearly all of them).
No real performance benefits on the street (a smidgen more kph over 400m), and a big negative - loss of power at the bottom end. And that's only when it's done properly, more often than not it's a 'poor man's' hatchet job - which has even worse response.
Sequential twins are far and away the best choice for a daily driver/street car.
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3805702
Thanks for the post. I thought parallel (never having owned one) would be better??? I'm a TT noob, could you explain why the parallel setup on an RX7 would reduce response? I know with sequential the smaller turbo gives quick boost, followed by the larger turbo for top end- but it they run together what real-world effect does it have?
Edited by R338OY
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3805771
It's not the same as the supra set-up.
When you remove the sequential system you don't get the low-down spool that the primary provides. Instead, you get boost later (somewhere around 3500 or 4000) - i.e. lag. It's like having a shit single (so you might as well get a good single). You don't really want to be taking low-end response away from a car that doesn't have much capacity (and therefore torque) on the menu.
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3806144
dude dont take it word for word.. someone could rebuild for 3k.. some could do it for 10k.. depends wat else u do, porting, studkits, which seals, how may housings need replace, how many rotors need replace. i could have my block rebuilt for 3k if it was just replacing seals.. and my housings etc were fine. its just like comparing a 2500 paintjob with 10k job.. exactly the same shit.. just different work and different quality
seals will depend on which type again.. i said MOST PROBABLY.. i use PTS seals and its a must to run premix... and premix has nothing to do with octane levels.. its just lubrication for ur seals.
lol!! read it again.. premix - 2 stroke oil... not octane booster man..
so read more carefully b4 u try take some1 apart thanks
Edited by Kin
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3806416
i ran pts seals and i didnt run a premix.. wtf for. every rotor engine has oil squiters for this reason.
Its just a myth.. premix belongs on 2 stroke motors and despite what most people believe rotarys are 4 stroke motors.
as for rebuilds.. i got the engine with the lot.stud kits, pts seals, bridgeported (exhaust included) had rotors balanced and 1 housing replace and some race bearings. 5k later... :P
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3808575
lol.. mate... its up to u wat u do. ur seals are just going to wear out without premixing
maybe speak to the makers of PTS seals.. ask them why you need to premix
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3808648
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
