  • Replies 120
WTF people!!!
THIS IS AN SAU CRUISE!!!
ANY skyline can come. It's not car specific. If it was i'd go over to R31skylineclub.com and post it there only.
even 180's or silvias could come for all i care.
As long as there is no idiots then we'll cruise our asses off :O
Originally posted by rs73
oh, ok then... chill off R31Nismoid :)
me is chilled dude :uh-huh: :uh-huh:
Just all this (not having a go at you man) can this come, can that come...
anyone can come... :O
i'm just organising this as we NEVER have meets (well altely anyway
as for your car... you got like 3 weeks :)
