fatz Posted April 17, 2008 Share Posted April 17, 2008 i need a bead roller for my ic pipes only one ive found is below 550 delivered (looks like a good bit of gear) http://www.pro-tools.com/m2.htm anyone one know of somthing similar i need to make nice beads on 3 inch mild and staino bends cheers pete Link to comment https://www.sau.com.au/forums/topic/215278-ic-bead-roller/ Share on other sites More sharing options...
fatz Posted April 17, 2008 Author Share Posted April 17, 2008 oh and i cant spell Link to comment https://www.sau.com.au/forums/topic/215278-ic-bead-roller/#findComment-3802470 Share on other sites More sharing options...
VB- Posted April 17, 2008 Share Posted April 17, 2008 checked eGay? Link to comment https://www.sau.com.au/forums/topic/215278-ic-bead-roller/#findComment-3803201 Share on other sites More sharing options...
Craved Posted April 17, 2008 Share Posted April 17, 2008 pete Hare and Forbes (www.machineryhouse.com.au) has Swage and jenny's with 175mm throat for 0.7mm mild steel for $395 they are in northmead Link to comment https://www.sau.com.au/forums/topic/215278-ic-bead-roller/#findComment-3803343 Share on other sites More sharing options...
fatz Posted April 18, 2008 Author Share Posted April 18, 2008 peteHare and Forbes (www.machineryhouse.com.au) has Swage and jenny's with 175mm throat for 0.7mm mild steel for $395 they are in northmead you champion ill check it Link to comment https://www.sau.com.au/forums/topic/215278-ic-bead-roller/#findComment-3804515 Share on other sites More sharing options...
W0rp3D Posted April 18, 2008 Share Posted April 18, 2008 i need a bead roller for my ic pipesonly one ive found is below 550 delivered (looks like a good bit of gear) http://www.pro-tools.com/m2.htm anyone one know of somthing similar i need to make nice beads on 3 inch mild and staino bends cheers pete that link says its $295 Link to comment https://www.sau.com.au/forums/topic/215278-ic-bead-roller/#findComment-3805257 Share on other sites More sharing options...
Beer Baron Posted April 18, 2008 Share Posted April 18, 2008 that link says its $295 yes... USD + freight. Link to comment https://www.sau.com.au/forums/topic/215278-ic-bead-roller/#findComment-3805449 Share on other sites More sharing options...
rb26s13 Posted April 25, 2008 Share Posted April 25, 2008 ive been looking around for a decent one for a while now for the right price that can handle doin 1.6mm stainless pipe.. havent found one yet goin to look at making one in the upcoming months/weeks Link to comment https://www.sau.com.au/forums/topic/215278-ic-bead-roller/#findComment-3822681 Share on other sites More sharing options...
Craved Posted April 25, 2008 Share Posted April 25, 2008 getting into a couple of grand for ones for 1.6mm Link to comment https://www.sau.com.au/forums/topic/215278-ic-bead-roller/#findComment-3822887 Share on other sites More sharing options...
rb26s13 Posted April 26, 2008 Share Posted April 26, 2008 getting into a couple of grand for ones for 1.6mm that is why im looking at making one rather than putting a bead of weld around the end of the pipe Link to comment https://www.sau.com.au/forums/topic/215278-ic-bead-roller/#findComment-3823695 Share on other sites More sharing options...
6 SPD SX Posted May 19, 2008 Share Posted May 19, 2008 that is why im looking at making one rather than putting a bead of weld around the end of the pipe If you make one post up how u did it!! Link to comment https://www.sau.com.au/forums/topic/215278-ic-bead-roller/#findComment-3877360 Share on other sites More sharing options...
