hey im wondering if ppl can post up pics of the their boot install n sub boxes in the boot of their 32 gtr or gts-t.Just wanna get some ideas cos my sub box is too big n to fit it i have no spare wheel.Not cool thanks everyone look forward to seeing them
https://www.sau.com.au/forums/topic/215287-r32-gtrgts-t-sub-box-pics/
hey mate i don’t have any pic's just yet but i had the same problem that my sub box i had from my old car is just to big for the skyline boot.. I’m in the process of designing and making a custom boot with the fake floor and amps in the floor also. I’m going to use to tyre well and lift it up from there. il give you some info as soon as i get started should be this weekend..
have a good one
niran
hey mate i don't have any pic's just yet but i had the same problem that my sub box i had from my old car is just to big for the skyline boot.. I'm in the process of designing and making a custom boot with the fake floor and amps in the floor also. I'm going to use to tyre well and lift it up from there. il give you some info as soon as i get started should be this weekend..
have a good one
niran
thanks mate thats be good
i went with a small trapezoidal box from autobarn. It only just fits and you will need a sub optimized for a small enclosure to make the most of it.
I managed to fit it while retaining the spare and all boot trim.
I removed it all a month later when i started going to the track :P
  • 1 month later...
You can buy a sealed enclosure for a 12" sub from JB Hi-Fi made by a company called Q-Max. It's just the right size to fit in the R32 boot, you just have to remove the trim over the rear windscreen wiper motor, slide it in, and replace the trim. The enclosure is like $89 or something? Here's a photo of the one in my boot:
I prefer sealed enclosures for their punchiness, anyway. Plus they're smaller so you don't lose as much bootspace. And they look better. :)
Here are some better photos.
You can see in this second photo just how snug the fit is. You can also see why you need to remove the trim over the wiper motor to get it in as well. The good thing about this is that the box is easily held in place.
Edited by HuH
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
