current setup is
3.0L
3.5inch dump to cat then 3" all the way
44mm tial gate with .9bar spring
6boost manifold
GT35/40 .82 housing
the car just cannot hold boost. its making 300rwkw at 4000rpm and just keeps going because it cant hold the boost.
wanted to ask the gurus out there wat are the main causes?
44mm gate cant possibly be to small?
Dump to big?
faulty manifold?
trying to dc the gate, so it shouldnt make any boost. which will rule out the gate theory.....
was wondering if anyone had any other ideas?
*******************UPDATE**********************
blue = with gate
red = without gate
its defiently the manifold. it just cant flow enough air.
next step is possibly redesigning the manifold to have 2 outlets merging into one or getting a new one.
or a bigger housing like mentioned above which i doubt will help due to the manifold.
on a positive note.....quite responsive as u can see lol
Edited by R34NRG
https://www.sau.com.au/forums/topic/215455-huge-boost-creep/
  • Replies 140
Posted Images
current setup is
3.0L
6boost manifold
GT35/40 .82 housing
Dump to big?
faulty manifold?
so boost is dropping off below the .9bar ?
or do you mean the other way around and boost is increasing?
boost in increasing...just keeps gettn higher and higher.
we set it at .9bar (gate spring) and it will go as far as 22psi
Edited by R34NRG
Drop the exhaust from the dump (before cat) and see what it does.
Failing that, DOUBLE check the gate is connected correctly (hoses are the right way around) sounds like it might not be as this can be a cause for it to skyrocket with boost for no reason.
After you find those two things out post back.
I would also up the gate spring to 16-17psi if your going to run over 20psi
do a careful dyno plot with the wastegate disconnected, the vac line
this will mean unlimited boost (almost like how it is now) so dont trash it on the street, dyno only
a great way to kill your engine is by stuffing around with the boost on a fresh new engine
if you get the same result, either the vac signal to the gate is incorrect or the gate isnt working correctly
how much boost do you want to run ?
gate is 100% connected correnty. one of the 1st things we done.
not so sure about taking off the exhaust.
wouldnt that cause spike and not creep?
the cars currently on a dyno as we speak......
we are dc-ing the gate atm to test that theory......if we dc the gate it should make no boost right?
we plannin to run 20psi for a start.....not sure how high we willl go
Edited by R34NRG
if the gas isnt being bypassed through the gate due to a flow blockage after teh gate - then this can cause the boost to creep - hence the suggestion to remove the exhaust
what boost controller you using? how many vacuum lines to the gate?
2 lines to the gate, they are the right way around as we checked them with a diagram (Me and the mechanic both went over it at the same time)
atmo gate, exhasut wont matter
boost controller is AVCR set everything to minimum (basically turned off) so should be running of the spring only.
current test is holding gate completely open to see if its flowing adequately
What do you mean your not so sure?
You dont even know whats causing it, drop the exhaust and see what it does... and double check the gate.
There isnt much to infinite boost climbs, its only a few things that will cause it.
blockage/restriction after the turbo or something not connected correctly before it
Exhaust WILL matter. Come here asking for help and then tell me it wont matter when you obviously dont even know?
Why ask for help if you know it?
found the issue.
droped the gate off and its still causing creep.
the manifold isnt flowing enough air to the gate so thats why its creeping.
very hard to believe being a 6boost manifold.....
only solution atm is possibly redesigning the manifold.
Edited by R34NRG
I dare say that the 6boost item is a tried and proven design, you are not the first to use it and many people before you have had no issues.
It seems you unfortunately don't want to listen to any advise given to try and help your cause.
Before questioning the work of someone else, do the VERY SIMPLE test:
- Unbolt the cat from the dump pipe and do a power run. A restriction in the exhaust causes back pressure, thus causing boost to creep/increase.
If you are not prepared to listen to any advice, best not to ask :P
What is the I.D. (Inner Diameter) of the wastegate pipe/flange, before the wastegate?
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
