Since I'm a newbie (in here at least), I thought I'd ask a simple q. And yes, I did do a search first :D
I've got one of those mobile phone car kits for my nokia 8250, but I was looking at getting a new car and its pretty inconvenient to buy a kit for a given phone and have to change the kit if I buy a new phone.
So.....that was a long winded way of saying, is there such a thing as a head unit that can connect to a mobile via bluetooth wireless, and if so, has anyone bought/used one?
https://www.sau.com.au/forums/topic/21553-newbie-q-mobile-phone-via-head-unit/
You could get a bluetooth car-kit to use with a whole number of bt equipped phone but even these will prob only work with *that* brand of phone :D
They *are* cool in that you don't neccessarily have to change cradles with each phone, though.
Headunit? Hope you're not talking about stereo headunits?!!? All you could od is use the yellow wire from the car kit to mute the stereo when a call comes in.
Hope this helps a bit...
Adrian
buy a "car baby" no wires the thing simply clips over ur phone and u tune ur stereo into the frequency it tells u to. they work great and totaly transportable and only cost about 70 bucks
thanks for the responses everyone!
bless_you, this is the head unit you mean?
http://www.alpine.com.au/product_pages/fan...ce_page_new.htm
this is close to the sort of thing i was looking for but its limited in # of models it supports, thats why I was hoping for some standards based wireless.
For the guys that mentioned the FM receiver thingies, the speaker thru the radio bit makes sense, but how does the mike work?
2rismo, got a link to one of those bluetooth cradle products.
lol! smarteq! recognised the pic, now I know the brand of my current car kit!
their "universal kit" looks interesting:
http://www.smarteq.com.au/docs/productBroc...salBrochure.pdf
anyone used these?
there was some stuff at nokia.com.au that they have a kit but no details...bastards....
thanks all
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
