Slipping Clutch After Gearbox Swap?
Hey folks,
I just put a rb25 box in my 4door 32, its the old hpi drift project car...Box works fine but now the clutch seems to slip near the top of the revs! Its a os giken twin plate, is it just coincidence that its gave up the ghost the same time as the box? I got a small oil leak at the bottom of the box, could this be leaking on the flywheel?
Anyone had this problem?
Any help is appriciated!!!
Check that your clutch pedal box aint broken the spot welds.
Same ting happened to mine one my r33 when I changed to a 3lt and up graded the clutch and big poundage pressure plate.
when you swapped the boxes over, did you check how much meat was left on the clutch discs?
if the clutch was fine, and it was oil making it slip, theres more chance the rear main seal leaking from the engine than the box itself. It would have to be leaking quite badly to make it slip, ie you should be dropping oil on the ground.
did you setup the clutch pedal properly, with the threded bit at the end of the clutch master cylinder on the cabin side. if its on to far it wont be letting the clutch plate release all the way.
 Share
    • Took a little trip  went to nismo hoping the get my fuel tank hoses and unfortunately they told me they didn’t have stock luckily I was able to go to a Nissan parts store and they were able to order them in for me  then can home and cleaned the tank with some degreaser and fitted the new hoses before putting it back in the car
    • 100% I’ll hack into the 33. Strap a turbo onto the RB25DE and/or put the 25 head on a 30 block. 33 passed in cos the reserve was too high. I’ll try lowballing it again and negotiate. Aim is to have it landed and on the road for under 15k, then spend the same amount on top in mods.
    • It's generally best practise to run 1x run without VCT enabled, then 1x run enabled till redline. Overlay the two torque graphs and you'll find the desired RPM to turn off VCT. Sometimes, it might be even worthwhile turning off VCT earlier control torque/cylinder pressure and using VCT purely to spool the turbo.
    • They sell them in Malaysia for about $4
    • First time I ever have issues with Amazon, but my wife often tells me to keep an eye out for fakes. It finally got me. I wrapped up the conversation with Gates. The gentlemen I was talking to seemed to hate his job but the response time on their technical support is outstanding. He stated that the hose is marked with some variation of "SAE J30R10" but that if you only purchase a 1 foot length like I did, it is possible to get a cut between markings and have a blank hose. To no ones surprise, he stated the swelling and "gummyness" isn't normal and to replace/buy from somewhere else (He mentioned NAPA). I'll toss a small end of the new one in gas for a few days before pulling the hanger out again, just to be safe.  Hose should arrive Monday. For those running multiple pump in tank hangers, you know the joys of getting them out and back in. I'm surprised I haven't destroyed my level float yet.  Lastly once I wrap all of this up, I'm planning on hitting the dyno again in 2 weeks while I'm on vacation. I realized recently that my VCT is set to turn off at 5000RPM. I'm surprised it wasn't increased while I was on the dyno last. I'm expecting I can increase it to ~6500RPM, if not more. Should hopefully get another 15-20kw out of it. I also want him to revisit my knock thresholds. I'm occasionally getting false knock around 3000rpm.
