  • Replies 76
one thing that all rb motors are going to need at one stage or another is a overhauled ignition system, wheather you go for replacement direct fire, or go for a wasted spark system, this is just as good as putting a free flow exhaust manifold.
you notice the difference.
you'll have money left over to buy a programable rom for your ecu.
your a goose.
i have over 350 rwkws with the standard coils and ignition system, running 24psi daily.
would you like to respond to this?
My advice:
get a bigger dump pipe and front pipe (does not have to be split, the big bell mouth ones work well too). also doesn't have to be new either. That will be anywhere from $250 to $500 depending on what you get and if it's new or used.
then I would get your ECU chipped and tuned. the toshi remap seems to be popular. when you get this done also fit a cheap bleed valve and up the boost to 11 or 12psi even that extra 1 or 2 psi will make a difference and make the car feel a bit nicer. The remap and bleed valve will eat up the rest of your $1000 budget. but you should get some good gains out of those mods. :down:
Mate I am actually in the same boat as you except I have an R34 GTT - currently has cat-back (came free with car) and boost controller ($30) running 10-12psi. I also want to spend minimal money - My plan is:
Dump pipe - $199
Hi Flow cat - $160 (you already have this)
FMIC - $300 (not really needed but hey I like the look).
SAFC NEO - $250 (brand new delivered, buy from the USA dont get ripped off here)
Tuning for above - $100-200.
Thats $1100 for me or $649 for you (as you have cat, R32 wastegate (10psi) and dont need FMIC). Personally I think SAFC is a wise investment, these cars run sooo rich with exhaust...I get 350km to a tank driving normally, everything is serviced/new, which leaves the air/fuel tune.
I only have one rule when modifying and thats make sure everything you buy can be taken off and sold seperatly when you sell the car, i.e. KEEP ALL YOUR STOCK PARTS. End advice.
Hey thanks for that!
Would you maybe pm me the details of where i can get the SAFC?
Whats the difference between the toshi remap, the jaycar fuel controller and the SAFC tune?
I havn't looked in a while but I just did a google search of US performance shops - also US Ebay had multiple new SAFC NEO's for under $300 delivered to your door in Aus.
^^ Also in responce to Decim8 I have had multiple X-Force exhausts (previosly on a WRX and a VR4) and never had any problems with them, why pay double for a brand name? But thats just my opinion not saying your wrong.
if you shop around you should be able to get a FMIC kit and front section of your exhaust for $1000...
You should be able to fit it all yourself, they are both easy to do if your not confident just take your time...
I think the best mods are the one's you d yourself a lot more rewarding.
I speak from experience when i say
get someone to fit the dump for you!
Good luck trying to undo the stock screws without snapping anything.
Is a Nistune ROM and remap essentially the same thing?
Hyperdrive in W.A say they can remap it and tune it for $800.
Is that reasonable?
Also, i have heard that remaps are better then a SAFC and tune, but i have nothing to base that on.....
Nistune is an advanced re-map. It accepts live changes making it easy to tune.
It also comes with software pretty much featured to the level of a power FC.
I had two rb20 cars.
One got an SAFC and 14 psi and the other stock boost and nistune.
http://butters.throwinghandles.com/file_st...veditvsSafc.jpg
Thats the comparision graph. The nistune does make less power but that is only becuase it has no extra boost.
You can clearly see the difference in the quaility of the curves. I won't buy an SAFC again !!
Driving them is worlds apart to the Nistune is so much smoother and feels almost as fast as the higher hp tune.
OH and as for SAFC not making any more power.
sus out this before and after SAFC.
http://butters.throwinghandles.com/file_st...fcTuneSmall.jpg
the AFR's of the scale without the SAFC and thats just with cooler, zorst and boost.
i think in the end you gotta try things for yourself...
i have been running 14psi with the stock turbo and smic on my 32 for 2 years/50000'ks and its still going strong....
i also have one of those china manifolds that is supposed to crack a week after you buy them and mines been fine for 50000k's
of all the mods i have done i have found that good tyres are the best bang for the buck.....
i have one of those ecu remaps and i can hardly notice the difference...
taking out the sub, rear seats and all the trim behind the front seats made heaps more difference..
but changing the castor, and camber bushes to adjustable did f**k all..
thats me and my situation its gonna be different for everyone...
Ok here's the update...
Dump is definately on the cards, i thought i might first just try to source something decent second hand. Anyone?
As for remap i did some research and spoke to Toshi (Great guy who knows his stuff! Thoroughly recommended!), he was even kind enough to show me what he could do on my car with the road tune, try before i buy type of thing which was a real learning curve for me. BUT even though my car is still as i first posted as i didn't really feel any more pull from the tune, a smoother overall delivery of power definately, but not any more pull. Toshi recommeneded i try a front mount, dump pipe, hiflow, fuel pump and airflow meter to really make the most of the tune, which i can appreciate but i'm not going to do...
Toshi spent a long time and did a great job but i just think my mods i have done even when i get the dump pipe can't justify the tune... not just the money side of things but just the fact it didn't change a hell of a lot with my setup..
I'm not sure if anyone else has experienced this with same mods?
So i'm still not sure what to do next...
A few have said boost controller and up the psi but my friend had a bad experience with boost creep in his 33 with similar mods except for FMIC snd dump pipe and blew the turbo, which kinda scares me off.
The R32 Rb20 has less ariflow than the Rb25 in the R33 gtst and as such the turbo can tollerate a little higher boost, as at the same pressure the Rb20 airflow is lower meaning less shaft speed on the turbine. Less power too.
No one has really mentioned replacing the 02 sensor?? Have you replaced it since youve had the car?? if your going to put on a dump pipe you may as well spend the 100 or so bucks for a new one as you can remove the old one and install the new one while the dump is off? good for a few kws i guess if you still have the tired old factory O2 on there. i believe they are supposed to be replaced every 40,000ks or something??
but yeah definitely go dump pipe/hi flow cat converter first
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
    • Yeah it is wild how much wider the Yokohama A050 in 255/40R17  vs Yokohama AD09 in 255/40R17 sits on the 17x9 +22 considering its even from the same brand and adjacent product family
    • Would love to see some examples of WMI making the same as E85. Only thing I've ever found is this one.  Which suggests WMI is not worth much at all.
    • And now the washer bottle looks like an orphan. You're going to have to spend money on a wrinkle black painted fabbed ally one of those. Oh, and the brake MC res. That won't look any good after you've gotten rid of the washer bottle. You going to need to go back to work to keep up with this?
