Parts required to complete R34 GTR bonnet conversion,
1 R34 GTR bonnet.
2 A pair of R34 GTR bonnet hinges.
3 An R34 GTR bonnet latch.
4 An R34 GTR bonnet stay.
5 An aftermarket mole to join the GTR bonnet to the standard R34 front bar.
Thx mate.. pretty crazy... suppose you bought the bits and pieces from nissan ?
PHAT!.. Id like to drive a car with reclinable bucket seats like yours and compair them to my fixed back.. see how big/small the diffrence is..
Nice seats Eug very similar to my ones I had in my 33.. I miss bucket seats so much.. I'm too big for the dam s13 seats lol
i've ridden in a side of bride ergo 1.5 which is more fitting for different body types from tall/fat/skinny it still holds you in.
a fixed back is awesome - such good holding capabilities, can be uncomfortable for daily driving though - the car is already uncomfortable as it is.
the R34 GTR seats are a very good compromise, they are suited more for the smaller driver though. I'm 170cm and around 70kg and i'm quite snug in them.
if only you lived in brissy
cheers... yeah they are awesome. pity they are worth a turbo conversion/half a build of a new motor. worth it though - if you actually use them for what they are meant to be for.
hey eug
nice center console :w00t:
hahaha nicely spotted... bah who needs it!
those holes in the seat are begging to be filled with a harness!
YOU KNOW YOU WANT TO! :thumbsup:
probably not for a while, looks like the car is coming off the road soon. target is 170~200 rwkw NA
you guys might hate me for it, as it won't be RB
If only you knew the grief you are about to wreak upon yourself eug. :thumbsup:
*Mr Burns's voicerolling finger tips on eachother*
Excelent
excellent indeed... doing the research on it now. put it simply there's no way i could achieve this kind of performance from an RB with the same amount of money. has the potential for 500HP and upwards!!!!
any takers???
P.S. - check out these V-Spec II seats that just came up for sale. got wood?
price i would budget AT LEAST $2.5K (maybe closer to $3K to your door) the auction ends in 30 mins
http://page2.auctions.yahoo.co.jp/jp/auction/b85665688
shouldn't you be selling your car, not modding it!! :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
