Thanks guys, these pics has to be the best photos I've taken.
Maybe if any of you guys need some photos of your cars, we can go on a photoshoot :) I'm in SE Melb by the way.
And as for lowering....EVERYONE tells me to lower it, but I don't want to spend too much money on this NA.
How much will the cheapest lowering be? WITHOUT cutting my springs...
Hey Guys,
Here is my little beauty, picked her up 2 weeks ago from the importers
Compliancer even left the xenons in for me.
Came with a stock tape deck which I had to quickly replace
Btw - FS rare genuin nissan dolby tape deck - $300 :)
Will take pics of mine soon and post them up White R34 with matt black 18" rims, will get my Bomex bodykit installed within the next 8 weeks, (have to wait for the rear bar to come from overseas, that delays me 5 weeks :D)
I will post my current set up ( practically stock) and when i redo my car all those weeks later if this thread is still alive i will post my future set up, with hood, front, rear, sides, lowered slightly, tinted windows etc etc all done.
just keep this thread alive!
its an awesome thread and it really shows the N/A scene here. Although personally a stock GTR looks far hotter than all our n/a's put together haha....damn those super sexy gtr's! :)
YES! I love the mount of 4 doors comming through!
But that makes mine less unique :down:
As for cheapest lowering.. all you need is a set of lower springs (shockies are advised too, unless you want your car to handle like oil tanker) try Lovelle or KYB or King springs.. all fairly cheap springs and shokie set ups
Maybe if any of you guys need some photos of your cars, we can go on a photoshoot :D I'm in SE Melb by the way.
I just bought a set of lowered springs, but not the best way to go about it. But it cost me $450 which included labour...
Prob best to get a set of adjustable struts... But then you could look anywhere from around $1000...
So in your case maybe springs to fit the budget.
Had my liner for a couple of month now. V happy with it :)
Charles89 is a very good friend of mine and kindly took some killer pics for me.
His now looking for clients interested in him taking photos for them.. PM me if interested.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
