Where'd you get the CF Lip from? How much are they?
Origin Japan make them. around $350. They are real carbon fibre, have to remove the boots brake light tho and then stick it on. If you want one let me know :)
Man.. I love that!
Its farkin fat! You NEED Genador style mirrors man!!!
Thanks Mate
Mirrors would be good, but i would rather get side skirts and rear pods first.
Actually as of 2 hours ago a passenger front guard would also be good, It got hit by something/someone while i was in the shops and left a nice scratch/dent
Edited by ShanO`
BLLLLLLIIIIIIIIINNNNNNGGGGGGGGG BLLLLLLLIIIIINNNNNNNNNGGGGGGGG!
I love it!.. the inner arch wheel photo is sick!..
How much more diffrent are braided brake lines than stockos? Pedal feel? Temp resistance?
It feels like u get alot more pedal feel. Still havent got out to the track yet to see how they pull up but in the hills they feel awesome.
Got the carbon surround from Superior in Japan roughly $190 which just sticks on top of the original. Leaving the gauges like that :) if i was gonna do something it would be gtr mfd but not just yet lol.
Hey guy's
Im only on my L's n just brought this N/A r33
Here's a pik... hope use like it!
p.s any modification ideas/opinion's be awesom
thanks
hey man
thats a hot skyline u got
do you know what type of body kit u got?
so what mods have u done to it?
pm me
thanks
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
