I went drifting again also :) This is at the 'Stadium Drift' Event in Moree, held by Raceline. I placed 3rd in the Level 2 class.
Grey NA 4drs FTW :D
Edited by -Jimmy-
Did a few little mods to my car..
Got a carbon fiber handbrake and gear surround
Did a brake upgrade and painted the calipers gold. Also matt blacked my wheels.. looks a Shyte load better then silver.
and I just like this pic a friend took cause its trippy..
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
