Great angle shane'o!
Did you manage to hold onto it?
Lol.. what is that to the left of your car?
An under tray?
Drifting seems to be an awesome way to loose weight out the car.
Last time I went, I had 3 interior pannels rip/tear/break themselfs off the car
Edited by GTS4WD
An under tray?
I'm pretty sure I held it, I cant remember spinning on that corner at the last few days I have been to.
That thing beside my car is most likely a tyre carcass...
I haven't had any real damage done to my car while drifting, only a bit of paint missing off my front bar and rear bars from just scraping tyres/barriers...
Oh and they dont like it when you do this :P
dirt turbo :P
What diff is in it?
It is a Nismo 2way mechanical, it has a 4.083 ratio (same as the original auto diff that was in the car).
Bought it second hand in housing for $650 just over 2 years ago, have put over 30,000kms on it and it hasn't missed a beat
everytime i see this stupid thread i ask myself 'what is the difference in looks between a non-turbo and turbo car? (apart from pissy little brakes)'
My car came factory with turbo spec brakes, so the difference is zilch.. apart from the 3inch to the muffler that you can see on skylines coz the ass is so high up.
My R34!! with my nephew rex
its funny how your on ur red p;s
and ur nephews full lisence :)
Here are a few of mine, had it resprayed a few weeks ago and had the bodykit fitted. Used to be blue over silver 2 tone, now its a custom blue with 2 pearls: purple and green.
post-9734-1196398516_thumb.jpg what the colour actually looks like in the sun.
love it
Here's some pics of my n/a 34..... i've been gettin mixed opinions on if i should lower it... any thoughts?
nah ride height is good
God I hate Hot4's...
... Their need to plaster every page with half-naked girls detracts from the point of the magazine - the cars. So glad HPI & Zoom don't do that shit.
i dont buy it at all. only got it cause my mate told me my 34 was in it....
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
