just thinking is it worth the $800 for a remap?,has any one heard of engine failure due to this?..just wana do the righty by my engine...thanks
by the way the car is running 10psi,and has a big fuel pump,i have been giving her a bit of a thrashing lately, hope ive done no damage......
it might be ok. i was running a stock r33 rb25 turbo on my rb20 and untuned it was leaning out slightly on 13psi above 5500rpm. only to like 13.5:1 afr. your running less boost so it might not be leaning out too much but i think its best to get it atleast checked with a wideband o2 sensor just to know whats going on.
but if you really want to do right for your engine go for a remap, if not a safc.
it will b ok as the afm will compensate for the extra volume of air entering the engine. although u will find it will b running a lil lean as the boost has been raised. but it will do this even with the stock turbo. fittin a apexi SAFC-2 will fix this n b cheaper than a remap. it will also give u more top end power as the a/f ratio will b at a more power productive level. remember tuning is the most important aspect of the power and engine makes. an engine could hav all the bolt on's in the world but its the amount of fuel and air, and when it is ignited that makes the power
Absolutely fine, I ran my RB20 with a series1 33 turbo for nearly a year on 12psi and regular heavy beatings :D
Oh and unless your fuel pump is dying (which it's likely not as you say it's got a bigger one) it's likely running rich as opposed to lean, what an SAFC will do for you is a cheap way to lean it out a bit and gain some more top end power.
I didn't bother with any of that shit and waited till I got the 30 in before I got it tuned properly (remap).
Edited by bubba
I am about to put in a RB25 turbo from an R34 on to my RB20, and I was advised to get it tuned straight away as it will throw out all the air to fuel ratios......
If you boost the RB25 turbo to 12-14 psi, i would be a little concerned about it leaning out......
Edited by Douse
it will but not by much. the extra flow will be picked up by the afm and the ecu will do its best. like i posted earlier i was seeing afr's of around 13:1 on 13psi, so not too bad.
My 20 w/25 turbo with stock fuel pump was seeing around 13.5:1 but boy did it go like a shower of shit heh.
Was pretty lean so did the fuel pump and untuned it made 246rwhp (@12psi) so I was pretty happy.
A tune will pretty much get rid of some of the lag (by smashing in timing down low) but I didnt see the need at that level, I preferred to save my money for the 30+bits.
Edited by bubba
i ran a 34 neo turbo on my redtop 20 for ages with no tune, was very very rich, when it did go on the dyno the afr's dropped of the scale to below 10:1
got an old style safc tuned on it and picked up 50hp and heaps better fuel economy:)
hey guys while the suject is up i also put a r33 stock turbo on my rb20 and its untuned i havnt been thashing it but whenever i do give it some it has no power since the new turbo is that normal
Edited by ACTIV32
No that's not normal, can you quantify "no power"?
yer well the power is probally equal to a stock r32 with its original turbo
i put it in my self and i checked everything twice i dunno, bizzare
i thought you had to get a tune for it to start giving th correct boost
Yeah did you use the actuator off your original turbo or off the new turbo?
R33 actuator is 5psi, R32 is 10psi. If you are using the R33 actuator and do not have a boost controller of some sorts then yes, it will feel rather gutless :thumbsup:
R33 actuator is 5psi, R32 is 10psi. If you are using the R33 actuator and do not have a boost controller of some sorts then yes, it will feel rather gutless :rofl:
well there is my problem i was going to use the old acuator but i think thats whats blew up my stock turbo and yer t is stock cheers for the help guys
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
