Hi guys,
I just read your posts and msgs.... unfortunately at this stage we are fully booked and have had huge interest. More than we can cater for actually. As C&V have expressed that we cannot actually handle more than what we have I'll have to put a hold on it.
BUT if any places do pull out I will let you know ASAP.
Sorry bout that....
due to the huge interest though perhaps Sky. Aust. should hold a dyno day soon... just a thought...
cheers
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
