Heres the goods:
King Spring Lows $100 excellent condition
Bilstein struts used one month perfect condition otherwise, $600.. these retail for around 1200 btw
Bilstein struts brand new $700 perfect
Whiteline swaybars fully adjustable for soft medium and hard. unused as new $400
Cut off cannon 2.5 inch $10
spacer 4stud $50
4stud hub setup complete $300
i also have a fibreglass gtr bar thats getting unused will sell cheap if anyone wants it.
Im located in sydney pm me if interested. cheers
Edited by Zz_32
https://www.sau.com.au/forums/topic/216313-r32-parts-going-cheap/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
