I had it on my 1st gen eclipse and loved it! You just have to make sure if you have it tuned with the water/alcohol that it always has some in the tank! I had a warning light hooked up to mine to tell me when the tank was getting low. Almost all the rally cars have it on them.
http://cgi.ebay.com/ebaymotors/WATER-INJEC...sspagenameZWDVW
This is a good cheap kit, and it has the same pump as the expensive kits. I have installed this kit in my car and it works well, I only use water and it keeps the detonation levels right down.
Fairly easy to install only problem is space, because the pump is huge and you still need a big water tank so you're not filling up all the time. What I did was made up a bracket and mounted the pump beside the the factory washer tank.
mate, a WMI failure can destroy an engine in seconds, I don't know if I would trust something like this.
Is it a sureflow pump?
Also, pressure switches aren't that good, because your spraying the same amount of water in at 3,000rpm as you are at 7000rpm, and since there is a lot of water going in at low revs, the car can shudder. I like the idea of variable water, brings it in nice and smooth, you'll use a hell of a lot less water\meth too.
Kits are only $600 now, and if you can' afford a kit at $600, why are you chasing the power, or even own a skyline? Sounds harsh, and I apologise, but saving a few hundred on a cheap unknown kit could cost you well into $4,000 on a engine rebuild?
agreed, with injection you are always treading a fine line. Best to use better gear for peace of mind.
i havent used it for about 10 years though.
would be a waste of time - you'd probably lose performance because you can't advance the timing in a factory ECU.
Just for those that don't know - You don't get any performance gains for just installing the kit itself. You need to be able to advance the timing to get the extra power.
Edited by The Mafia
Yep sureflow pump, looks exactly the same as yours.
I agree variable water injection is the way to go, you buy this kit and get a variable injection module for $50 and save yourself a few hundred against the over inflated aus company prices. I just don't see the point in spending more for the same thing.
I had mine setup with the pressure switch that only came on at full boost, it was also tuned to compensate for excess water provided at lower revs. I also used a small nozzle which had little no effect high rpm but stopped a lot of the knock I was getting in mid-revs.
So it's not the best setup but in practice it works well. I wasn't really aiming for more power like your setup just better cooling reliability as my intercooler struggles at times with the type M front bar covering it up.
Edited by BAMR33
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
