Hello!
I have a Nissan Skyline GTST engine and I want to fix Mazda RX7 manual gearbox.
My problem is that I don't know which flywheel to match them together. I want to know the flywheel model!!!
clutch plate --> pressure plate --> clutch pump --> clutch pedal --> OK
but unsure what type flywheel - please reply if you can help!!!
Sanjeewa
Edited by sanjeewa
https://www.sau.com.au/forums/topic/216479-flywheel-problem/
provided the stock flywheel and pressure plate fits inside the rx7 bell housing i'd be using them with an appropriately sized mazda friction plate to match the splines on the box.
Obviously you'd need to have some sort of bell housing adapter.
I'd have thought it'd be easier (and cheaper) to run the 25 box and go a custom gearbox cross member and tail shaft. My old S4 rx7 box was weak as piss....
Thankyou for your information!
the reason why I am doing this is because in Sri Lanka there are no manual Nissan Skyline gearbox. I'm thinking Mazda RX7 will be a good match for the Skyline GTST engine.
You could just buy one off the forum, and have it shipped over, much less work
+1 to weak as piss
You'd be better off putting in an RB20 gearbox. I've got one round the back you could have. they are also weak as piss so you'll be set.
The flywheel should fit...just, but you will need flywheel and pressure plate from the Skyline and clutch plate from the RX7.
Then the plate diameter is wrong as you would be using a 225mm clutch plate and the skyline is 240mm. You would either need to get a custom clutch made with the RX7 hub using the skyline outer plate or use an R32 GTS non-turbo flywheel and pressure plate with RX7 clutch plate which is 225mm...the same as R32 non turbo.
Either way, it's a stupid idea...don't be stupid!
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
