  • Replies 192
updated list of parts left;
nismo 320 white face dash - $600
momo steering wheel with boss kit - $100
sard turbo timer - $20
sealed lead acid battery - $50
speco boost guage - $20
razo sports pedals - $10
nismo white duracon gear knob - $40
clear front bar indicator lights - $40
carbon fibre painted wipers (3) - $30
interior lights - $10
roof handels - $10
unknown blue brake cylinder stopper - $20
white boot lock - $40
hose clamps (10) - $5
1.6m 6mm dia braided hose - $15
skyline car mats - $80
indicator/light stalk - $10
foot rest - $10
glove box - $10
ac unit - $50
centre console with white hand brake lever - $30
ignition plastic bit - $10
front seats with rails - $50 ea
rear seat - $50
seat belt set - $30
car carpet - $50
interior plastic around rear window - $20 all bits
kick panels - $10 ea
parcel shelf with speaker covers - $40
stock dash with 115337km - $50
door trims - $40 ea
roof carpet - $20
hks cat back exhaust - $450 has small dent
veilside rear bar - $50
veilside sideskirts - $50 both
tail lights - $70 both
boot and drift wing - $200
complete doors with electric mirrors, power windows - $150 ea
works emotion xt7 with tyres - $1500
dashboard - $20
bilstien suspension with sway bars and drift pinapples - $1500
jack and tyres changing gear - $20
gtr gearbox - $1000
rb25det out of stagea (has sump with front diff) turbo, computer and loom - $2000
r32 gtr front brakes and discs - $350
stock afm sensor - $10
standard cat convertor - $20
front dump pipe - $20
front right and left plastic mud guards - $10 ea
front windscreen plastic bit - $10
cheers,
Michael
Hey mate!
This used to be 4 stud yeah?? Judging by the space saver spare??
Anyway Not particularly interested in five stud setup but mainly interested in calipers and handbrake cables... Do you still have your 4 stud hubs frm when you converted it over?? I've been tols I can use them to convert the handbrake on my 180 to R33 spec whilst retaining my 4 stud...??
Anyway price and pics on calipers, handbrake cables and 4 stud hubs if you got em..??
Cheers,
Chris
Hey mate!
Cheers,
Chris
no handbrake cable or orginal 4 stud hubs.
selling calipers a disc together $350
How much for the standard gearknob ? Couldn't see a price, just a pic.
sold mate.
hks exhaust - sold pending payment
space saver rim - sold pending payment
tail lights - sold pending payment
pedals and nismo gear knob - sold pending payment
wipers and plastic key surround - sold pending payment
car matts - sold pending payment
veilside kit - sold pending payment
photo's will be taken over the weekend
cheers,
Michael
hi,
i just tried to call (13/7 @ 10:28) but was wanting to purchase the side and front indicator plugs (not the actual lights) if you still have them available.
If you can return my call if you have these available.
Matt
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
