thinking about a pair of these turbos to replace the stock units.... and still be able to use the stock cooler inj fuel pump ect to push it up to around 300kw atrws what to guys think?
and at $2600 is that the hole kit? gaskits ect every thing you need to bolt them on? will my stock dump pipes bolt on?
https://www.sau.com.au/forums/topic/216772-gt2860r-5/
much between them in lag? i have heard 300rpm?....
Bit more than 300rpm mate, a lot more IMO.
Basically -7's are response like stock, and 300-330rwkw.
With the -5's you'll definately be aware your running aftermarket turbos on a GTR as there wont be any bottom end at all generally...
But will push a lazy 370rwkw upto over 400rwkw as others have done a few times and really come on song around 4000rpm from memory where the -7's just feel like a 4ltr N/A (easiest way to describe mine as they make mumbo so nicely and early)
Everyone i know with -7s/GTSS is as happy as i am :thumbsup:
https://www.sau.com.au/forums/topic/216772-gt2860r-5/#findComment-3828271
7s would be what i am after then...do they come in a kit? with all the gaskits ect? or are the gtss the only ones that do?....
If you plan on doing cams at a later date you will be kicking yourself if you don't go -5's.
Response greatly increases with a good set of cams dialed in correctly
As for the gaskets...you only get them with the HKS Kit..but you will be paying a lot more for this.
So buy your -7 or -5 Turbo's and get new gaskets elsewhere.
For piece of mind...get a N1 fuel pump and regulator
As for your 300AWKW's, have a look at others who are making this reliably on the UPGRADE thread.
https://www.sau.com.au/forums/topic/216772-gt2860r-5/#findComment-3829650
None of the garretts come in a kit (to my knowledge), unless someone is supplying it as a trader/business
GTSS's come with everything in the box ready to go.
Check the exchange rates, GTSS was cheaper a while ago (over all)
I think now the Garretts workout 300-400 cheaper once you source the gaskets, banjo washers etc over the delivered price of GTSS
Also for what its worth... none of the track GTR's here are running cams with either the -7's or the -5's
Must be something that others dont know? :D
https://www.sau.com.au/forums/topic/216772-gt2860r-5/#findComment-3829681
Early stages yet and no dyno sheet to prove it but i have just rebuilt my engine and have some 260 degree cams with the -5's.
Feels like its responding early to pedal input but that could be due to the shortened exhaust or the slightly higher comp, will get a few more kms on it and then its a dyno session so we will compare the old stock cams to the 260's.
https://www.sau.com.au/forums/topic/216772-gt2860r-5/#findComment-3830970
See I had 260's with my -5's and they have been taken out and replaced with the stock cams for much better results.
But so much of it has to do with the man twiddling the knobs as I'm yet to see anyone other than Ben get better results with stock cams over 260's for these size turbo's. You look at Mark and Russ who were basically running these size turbo's on their R32 and they went the other way with HUGE cams (272's). So each to their own on this front with what each tuner finds they get their best results with.
https://www.sau.com.au/forums/topic/216772-gt2860r-5/#findComment-3831760
Cams dialled in correctly can greatly increase flow of gases through the motor..thus decreasing the spool time of the Turbo's.This in turn gives you +boost quicker and a more responsive motor.
Many who have done the upgrades on a RB26 would swear either by -7's or -5's........
In a stock car....-7's work a treat.
Start to want some serious power and they become too small for the job.
-5's are in a larger housing than the -7's and this causes a little more lag.
Cams overcome this lag slightly...added to -5's...Poncams work a wonder.
If their is anyone who doesn't know about this...they should not be working on cars...fullstop. :)
Good luck with the install of your gtss Turbo's.
https://www.sau.com.au/forums/topic/216772-gt2860r-5/#findComment-3834359
If their is anyone who doesn't know about this...they should not be working on cars...fullstop. ;)
lol... so your going to say Racepace using factory cams in -5 and -7 cars... and funnily enough having some of the quickest circuit GTR's in the land...
Shouldn't be working on them?
rriiiiiightyo ;)
Quote of the month i think
https://www.sau.com.au/forums/topic/216772-gt2860r-5/#findComment-3834657
rriiiiiightyo :rofl:
I think you may not be comparing apples to apples......street and circuit are two different things.
Also, tuners who are dedicated to racing may have the best and fastest track cars, but they spend
a lot of time and money preparing them.There is no way they are going to make this effort on your car.
Also, gearing can play a big role in speed/spool/boost.
Changing gears can play a big role.
A GTR32/33 have 5 speed manuals...this means less gears..more longer times in these gears..thus more on high boost.
this is good for street cars.
A GTR34 on the other hand has more gears...less time in each gear...thus a leaser time on boost.
What cars do Racepace run..what are there specs...do you think they will tell you?
I wonder if they have not tinkered with gears etc etc.
My answer is an honest answer...if stock cams where the best for GTR's...why would we have so many different after market ones to choose from.All that time and money from HKS, Tomie, etc etc..is it all a waste.????????.lol
I think you can email them now...let them know..Racepace has decided this and thus it it true.
My statement stands....
https://www.sau.com.au/forums/topic/216772-gt2860r-5/#findComment-3835147
I'm really keen to see some 'stock cams' graphs with the benifits. It's certainly a different way of looking at the traditional and I'd love to know how it's supposed to work. :rofl:
hey pha71, should be getting my 33 gtr back today with new garrett 2860-5's on it, standard cams (but cam gears fitted), bigger injectors, pump, etc.....the turbos dont come with gasket set, mods need to be done to, oil, and water lines,and mods done to inlet side of it, tomei dumps dont fit to these, will get my mechanic to make up a list of mods needed to fit these up so you can get an idea...ps. not that cheap too do either, robbie
Edited by donkey
https://www.sau.com.au/forums/topic/216772-gt2860r-5/#findComment-3835155
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
