Hey,
Has anyone ever had troubles with their fuel hose swelling up and braking apart.. I talked to my mech and he reckons he only ever uses factory fuel hose cause all aftermarket stuff swells up within hours... and he is right, i tried some fuel hose from a hydraulics shop that said it can be submerged in fuel no problems.. and it swelled up and broke apart within 2 hours...
I am wondering about the blue speedflow hose... might be some better quality, but none of that cheap black stuff works either.. its only made to hold fuel on the inside... What can i do??
( this is in relation to inside the tank )
cheers
https://www.sau.com.au/forums/topic/216832-fuel-hose/
pleaase fellas...
tomoro i will goto nissan and ask for some of their hose they use inside a tank but i dont know how ill go.. fail that ill buy every kind i can and do a test
https://www.sau.com.au/forums/topic/216832-fuel-hose/#findComment-3828690
Get the nissan stuff - UAS has it.
About $70/metre though. I used about 0.5 metre I think..
Otherwise I think Nissan has it in 1m lengths. It has blue writing on it and feels different to other hose. Feels more flexible. I dont think it has uv rating but like you say can handle fuel on the outside.
Mackay sell some but I dont think it is EFi rated.
https://www.sau.com.au/forums/topic/216832-fuel-hose/#findComment-3829146
It has been talked about a bit on SAU, do look around.
People do try and use the factory allotted amount, as its of butyl inner / outer construction. Unlike the "inner" only of normal fuel hose.
I almost ordered a few meters of it from Nissan with some mates, but worked around it.
That’s pretty trick, UAS having it on hand.
Someone on here used some of that "fuel resistant, clear with single ply construction" stuff you see at hydraulic hose places as insulation between an 044 and cradle. Iv also seen it used for the pickup... not for the high pressure OUT though.
As for food for thought, some ppl have talked of stripping the metal braid off of Teflon hose (Speedflow, Earls etc) and hose clamping it on.
Edited by GeeTR
https://www.sau.com.au/forums/topic/216832-fuel-hose/#findComment-3829160
ok i went to nissan today and they said they have never heard of fuel hose inside tank being any different and looked on nissfast and found the piece i want and for 3" of it, costs $65. So im going to try the wreckers tomoro and just rape some VL commo or something cause we have no import wreckers!!!
cheers for the help guys, ill try repco too
https://www.sau.com.au/forums/topic/216832-fuel-hose/#findComment-3830695
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
