Make:Holden
Model:Commodore VY II SS
Milage:64,XXX
Transmission:M6
Colour:Cosmo (Dark Purple)
Complied?Yes
RWC supplied?Yes, as required
Currently registered?Yes
Price:27,500 ONO
Contact:0429994246 or [email protected] or PM
Comments / Modifications:Full exhaust, tinted windows, floor mats, tow pack, 2YR used car warranty.
Images:Yes
Exhaust includes pacemaker heat coated extractors, twin 2.5" Mandrel bent system with highflow cats, not too loud.
Tow pack is 2100KG Hayman Reece hitch receiver, fitted while I owned the car and only towed a 700kg camper once, this is not a flogged out towing car - still has orig clutch in excellent condition - no slipping.
Car has full service history with Holden while under new car warranty then with certified mechanic after, to keep the warranty the car must be professionally serviced. All receipts included.
2YR Warranty is a used car warranty and covers most major items, have scans of this at home if required.
Selling as we're moving overseas, car only goes to and from work and I'm averaging 11L per hundred K's in it on standard 91octane unleaded.
Will consider cheap run about as part payment, would be happy with VR/VS or similar era Ford but if you have something let me know.
Car has to go so make me an offer :D
Edited by ActionDan
  • 3 weeks later...
Guys I'm going to the car yards this weekend to look at trading this in, it's got to go as the lease payments would be better spent on saving to go OS next year. Forgot the asking price, make an offer and we'll go from there :)
I've found a suitable replacement car but obviously need this sold first.
Make me an offer guys, car has gotta go. Still looking at accepting trades as part payment.
Cheers
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
