So after recently moving and going from one lot of spares to two lots, we have no room and need to get rid of some stuff!!!
Tyres
No longer needed as I sold my 17" rims - we now only have 18" rims on our cars so they are pretty useless!
One set of four semi slicks - Yokohama Advan A048's - 235/40/17. 80% or more tread left - medium/hard compound. (photos further down in thread)
$385.00
One set of Porsche Cup slicks - 24-64-18.
aka 240-40-18. These are almost completly new. Again used for only one practice session. new tread depth is 3.1mm the LOWEST on these is 2.4mm.
so around 15% worn on average. (photos further down in thread)
$600 a set.(4) ($550 each new)
R33 Stuff
Cusco 6 point Safety 21 roll cage for a R33 Gtst - Steel one, bolt in not weld - decided I can't be bothered and it was a bit of a impulse buy. Bought it off another forum user... its used, ummmm might be missing a couple of bolts from memory but Il replace them before pick up.
$500 ono
Walbro 255L Fuel Pump (GS-342???) ready to bolt into a 33 Gtst.. comes on the std bracket.. ran out of power for my car, prolly did around 4,000 kms over 12 mths..! Was ok at 300+ rwkw but only with the gain turned down on the boost controller
$100 firm
Exedy 5 puk clutch - used for about 3000 kms... hardly worn, couldn't hold the 300rwkw... was fine at 270rwkw though! (photos further down in thread)
$300 ono
Std Flywheel - Just removed from car - twin plate setup reason for removal.
$100 ono
32 GTR SHTUFF
NPC rebuilt OS Giken TS2 twin plate clutch - Basically brand new except the splines are damaged on the friciton plate (riveted hub needs replacing on one of the plates) - push type $500 firm (photos further down in thread)
Gearboxes -
R32Gtr push type - partly disassembled, suits rebuild or anyone chasing a bell housing, input shaft is smashed - although you get all the smashed bits with it :thumbsup: - $250 (photos further down in thread)
R33 Gts-4 push type - 3rd gear is blown, (higher strength, extra ribbed bell housing) doesn't include transfer case - $350 (photos further down in thread)
R32 GTR Bonnet - couple of minor superficial dents/marks... 500 ono - photos next week as the bonnet is stored elsewhere and I need to get there on Monday after Texicana
RB26 Long motor - this will be rebuilt with forged internals, looking at expressions of interest before starting, buyer to have input on internals etc which will vary cost. Please PM your enquiries to Dave aka T04GTR and post in this thread so I can tell him to log on and check it out!!
Random - DR30 Coupe complete doors minus the mirrors, manual wind up windows, red & black trim, red and silver two tone duco - from a RS model. $500 for the pair.
Please PM or post here if interested. Willing to post smaller items, roll cage and tyres etc pickup only unless you can organise your own carrier.
  • Replies 46
Im keen on the good semis sould fit my 17*9 rims ok?
Hey Brad,
Yup, I had them on the zeddles which has 9" (well one is 8.5" :) ) rims.... no dramas :rofl:
EDIT: Spoke to Dave before, he used to have them stretched over his 9.5" rims on his GTR
[/u]R33 Gtst hard intake: Hard intake for standard turbo or whateva is the same? I have had this HPC'd in a candy blue colour - was on my car when I was still running a hi-flow and AFM... $50 Firm
Do you have a picture of this installed on your car?
I'm curious to know if it will fit on the Stag.
  • 3 weeks later...
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
