gtr33 gearset out off a 97model gtr gearbox, perfect condition $1000
gtr34 rb26dett head only done 10000kms comes complet with rocker cvers too. $2200
gtr33 and gtr34 tein coil overs HA model set of four in good condition full height ajustible $900 the lot.
gtr33 brembo rotors front only 324mm $280 the pair
polished fuel surge tank to suit skyline with fittings and lines, you just need pump to conect it all up. $250
hks fuel cut defender brand new in the box $250.
gtr33 tyres, set of four 255x40x17 all have 90%tread as new, brand is called venture tyres. $500 the lot.
gtr33 front bar lip, original plastic not damage off a 95 model, painted gtr purple. $250
gtr33 rear spoiler, with ajustible wing and carbone fibre panels on the sides, painted dark grey $400
[email protected]
https://www.sau.com.au/forums/topic/21711-skyline-gtr-parts/
I have been looking for a BNR34 GTR coil cover......
I have a BNR34 GTR engine but the coil cover or valley cover as they are sometimes called is polished and off a BNR32....
Would you consider a swap with my polished one or would you sell yours seperately? I would really like one so that it can suit the R34 head that i have....
You will notice that the writing is slightly different to the R32 cover also, as it says skyline GTR sideways in stead of twin cam 24 valve **i think that is the difference, cant remember****
Anyhow, i am very interested.... PM me as it look like you are online....
Tom
https://www.sau.com.au/forums/topic/21711-skyline-gtr-parts/#findComment-460499
  • 4 weeks later...
gtr33 brembo rotors front only 324mm $250 the pair
hks fuel cut defender brand new in the box $200.
gtr33 v-spec shocks $200 the four
skyline king springs, 50mm lowered, as new $200 the four
blitz dual sbc, green colour screen all still in box, used for 6 months only works perfect. $450
gtr33 troddle bodys $500 the lot.
gtr33 O2 sensors $50 each
[email protected]
[email protected]
https://www.sau.com.au/forums/topic/21711-skyline-gtr-parts/#findComment-514477
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
