I put a Bosch 044 pump in my car and didn't notice as much difference in the mixture as I thought I would. It'd be less difference for a GTR pump (less pressure) so I don't think a re-tune is absolutely essential but would be recommended. The ECU will cope to a certain extent.
I always thought that the reason cars are running rich at idle with bigger pumps is because the stock regulator couldn't flow enough to keep the pressure right. So higher pressure at idle and more fuel getting squirted in.
I don't think a mild upgrade to a GTR pump will cause that much of a problem. You can always take a little bit of fuel out with the SAFC if it runs rich, or fit a bigger regulator.
if the fuel regulator doesnt give you a fuel restriction (causing pressure build up) then you shouldnt have any change from getting a bigger fuel pump. after all its the fuel regulator that controls the fuel pressure not the pump. unless of coarse your pump is worn out and at high rmp its not able to pump ennuff fuel.
Well mine is a 93 model, which means if the 10-yr old pump is dying soon I wouldn't be surprised...
On the other hand, yea maybe the fuel filter is dirty and not allowing good flow of fuel.
However another Q: does a gts-t injectors up to the task if you use higher flowing gt-r fuel pump?
sorry, read my dyno chart wrong.
on higher boost setting at 11 psi the A/F ratio ranges from around 12.6 to 13.4... only after reducing the boost to 10psi the car managed to maintain between 11.5-12.5 A/F ratio and achieved an extra 14rwkw.
Reducing my boost increase my engine power from 140rwkw @ 11psi to 154rwkw @ 10psi
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
