  • Replies 58
people come on... leave this poor guy alone so he can peacefully go off and spend BANGN's money on buying himself something else!
***EDITED PM OP FOR THE INFO***
thats just a kick in the guts...
* get someone to drop off parts to you rather than picking them up yourself
* not have the money ready there for that person
* say thanks for the parts but not pay
* then have the nerve to ask people on the same forum to help you out buying something else!!!
I was going to help this guy out getting a good deal but now after reading this I wouldn't give him SQUAT
+1
Guys,
As much as it seems clearly obvious to most people what has happened. As stated before, there is two sides to every story. At this point in time we have only one side of the story.
While I can see that people would rather be warned, please go about it using the correct procedures.
Defamatory remarks made towards businesses or individuals will not be tolerated on this website - We understand that if you have had a bad experience with a business you want to warn other people of said experience. Unfortunately, the same publicly expressed opinion could be viewed as libelous and/or constitute an attempt to deter business from any individual or business. Australian law holds the site owner partly responsible for any defamatory remarks posted on said website, and that is unacceptable. Informing people via PM's is tolerated as it is not a public message. With this said, feel free to post any information about a business or individual that you have had good dealings with.
if he is chinese
just tell him to buy a bowl of fried rice and sweet sour pork for all your troubles
then some how still wake up in the bushes
btw have you talked to your friend about it yet?
Edited by viet_boi
1. I did not request for you to leave the parts on my door. You did that on your own accord. I did not even request for you to come out to my place you were apparently in the area.
2. You were suppose to call me to arrange a time as to be home to meet you.
3. I have been in and out of Perth dealing with matters for work and it unfortunately put issues like this (although they are important) to the back of my mind. I also did the "I will deal with that when I get back to Perth" which unfortunately when you get back to Perth it slips your mind.
This does not excuse my lack of communication and I do apologise, it is not like me to neglect matters of this nature. Please send me your details and i shall deposit the cash tonight.
BTW thanks for the feeble threats however;
1. A member of the police cannot knock on my door for matters of this nature.
2. An individual of the police cannot knock on my door on days off etc to deal with matters that are not official. Friends or not.
k thnx bai
There will be no more explanation on my part on this matter and I am sure the other parties are in agreeance over this small matter that it best be left alone from here. As soon as I have the details it will be sent.
Closed.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
