Wow! Looks like we should have an impressive turnout!
17. Smidy (maybe)
18. Hallam (HAL 32)
19. Hallam's +1
Oh and correction to Paul's username, should be HR31_RB20DET, my bad. Although he wishes he had the RB25DET powah!!! Hehehehe.
Where's Irish and Mrs Irish???? Won't be the same without the token drunken Irish...
Will get everyone to confirm definately next week, closer to the date and will also get onto Vish about organising a bite to eat beforehand.
Edited by Miss Niz
  • Replies 47
saw sally and irish on wensday for HID kits.. must say he wasnt sure if he could make it or not .. maybe a lil nagging will work ! oh Sus-t did you want a set of hid too ? maybe i can give them to you before the 24th so you can have em in the car also can get them for the Commi as well which is just H4
Okay guys, i have managed to book an 2 extra lanes for the night.
Could i please get everyone to definately confirm that they will be there, or please let me know if you had said you are coming, but cannot make it now. Bookings are essential for the Saturday night bowlings as the lanes fill up very quickly. Therefore if any one decides to show up on the night without putting their name down here, it will not be guaranteed that they will get a lane.
Thanks!
hmm i may be lawn bowling....looks like a big turn out though. will see i may be tryin to get the car running as well....and that is more important atm.
8 months and counting is too long.
22. Damian (Damit)
Thanks guys. I've given up trying to keep track of who's coming and who's not, seeing as i can't edit any of my posts and it's just getting all messy. Four lanes have been booked, which is enough for everyone who has already said they are coming above.
Nadeem and i will be up for dinner. As long as we aren't late to the bowling centre like last time and can all meet out the front in the carpark at 8.30pm, all ready to start bowling at 9pm.
Looking forward to it!
me and sal are def in, cant go 4 dinner beforehand, i finish work at 6 so ill be rushing to get there on time neway. but we will be there at 8.30. cant wait. are we just going are seperate ways or are we crusing around for a bit??
Sorry to take over the thread Teena , how about meeting point is Coffee Club Logan Hyperdome not far from the bowling place we can have a few chai's / drinks etc and head to bowl im brining about 4 cars with me, i'll be at the coffee club at 7-7.30 at latest
Awesome guys, can't wait to catch up! We'll meet you's at bowling at 8.30pm... We'll be in our VT SS.
Lol at Adam's welcome owl. I think he just wants an excuse to put something in between his legs again...
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
