You can not supply a car to the market modified from what the VIC states and that means for a dealer no mater who complied it be it external or not it is not to be modified until is has been sold and new owner has taken delivery.
Just because it has a compliance plate fitted, been pit passed or as a workshop you don't own the car it is to be as per the VIC states, when people spam photos of their car just as they pick it up with rust on bolts for things like the Pod Filter and BOV you can see it was never touched.
Their is a reason why the RAWS Guide was amended and it will be amended again if a couple of workshops are not shut down and it doesn't scare people into doing what is expected, no more DOTARS proving you did something wrong you now have to prove to them you didn't do any thing wrong.
  • Replies 160
lol Dave... yes, a mutual understanding is one thing, putting it down in written form is well... a little dangerous. And yes, DOTARS do visit this site... I've spoken to one of the guys on the RAWS team after he came on here to read up on some V35 info.
I'd just like to state, for the record, that I hold the guys at DoTaRS in extremely high regard - two big thumbs up from me guys :D
must have been a hacker who logged in and used our SAU account that afternoon.
A bit dangerous, yes, but that's how we roll at carizma.
We absolutely love DOTARS here, and especially the RAWS team.
well back on subject lol
got some good news today. its ready for pickup! sucks im working in cairns till tomorrow and dont get back till late night, so friday is definitely a day off for me LOL :P
heyz thats good to hear man. finally after 5 months aye :P . on the other hand i'm also getting my car back from the workshop this friday :down: can't wait to be an nissan owner!
Hanyou, glad to hear you finally got your baby! I really felt for you with your delays because I started my journey after you and finished before you :banana:
Are you enjoying it as much as I'm enjoying mine?? :P
  • 3 weeks later...
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
