BLK33T Posted May 4, 2008 Share Posted May 4, 2008 Clutch pedal gone all of a sudden whilst driving ... Hey, I was driving along yesterday and went to change from 2nd to 3rd when the clutch pedal just seemed to fall to the floor. Now when I push the clutch pedal down it doesn't disengage the clutch properly. I have to push the pedal as hard as i can to get the car into gear and to get it home i had to blip the rev in between shift so that it wouldn't crunch gears. It's going to Bezerkly tomorrow to get checked out just wondering if anyone could give me an idea of whats going on cause its doing my head in... Thanks Link to comment https://www.sau.com.au/forums/topic/217724-clutch-pedal-gone-all-of-a-sudden-whilst-driving/ Share on other sites More sharing options...
chiksluvit Posted May 4, 2008 Share Posted May 4, 2008 Clutch pedal gone all of a sudden whilst driving ...Hey, I was driving along yesterday and went to change from 2nd to 3rd when the clutch pedal just seemed to fall to the floor. Now when I push the clutch pedal down it doesn't disengage the clutch properly. I have to push the pedal as hard as i can to get the car into gear and to get it home i had to blip the rev in between shift so that it wouldn't crunch gears. It's going to Bezerkly tomorrow to get checked out just wondering if anyone could give me an idea of whats going on cause its doing my head in... Thanks most likely your clutch master cyl is gone change the slave cyl as well if you're doing the master cylinder check your clutch fluid level, if it's too low then top it up, pump the pedal up and drive it carefully to the mechanics to get it fixed the genuine master and slave cylinders aren't that expensive from nissan, so just save yourself the hassle and get new ones instead of messing around trying to rebuild/reseal the master cyl.. if the master cyl bore is scored then u've wasted your time rebuilding it Link to comment https://www.sau.com.au/forums/topic/217724-clutch-pedal-gone-all-of-a-sudden-whilst-driving/#findComment-3842299 Share on other sites More sharing options...
BLK33T Posted May 4, 2008 Author Share Posted May 4, 2008 ty Link to comment https://www.sau.com.au/forums/topic/217724-clutch-pedal-gone-all-of-a-sudden-whilst-driving/#findComment-3842668 Share on other sites More sharing options...
BLK33T Posted May 5, 2008 Author Share Posted May 5, 2008 was a spot weld on the pedal box that had failed ... all good easy fix Link to comment https://www.sau.com.au/forums/topic/217724-clutch-pedal-gone-all-of-a-sudden-whilst-driving/#findComment-3843227 Share on other sites More sharing options...
zebra Posted May 5, 2008 Share Posted May 5, 2008 I Wish I had an easy fix like that Just Pulled my slave off to change as I thought it had gone only to find that the locating/pivot bolt for the clutch fork has snapped...Yay Gearbox has to come out now Link to comment https://www.sau.com.au/forums/topic/217724-clutch-pedal-gone-all-of-a-sudden-whilst-driving/#findComment-3843560 Share on other sites More sharing options...
BLK33T Posted May 5, 2008 Author Share Posted May 5, 2008 ouch ... I feel for ya buddy, getting a workshop to do the work for you? Link to comment https://www.sau.com.au/forums/topic/217724-clutch-pedal-gone-all-of-a-sudden-whilst-driving/#findComment-3843822 Share on other sites More sharing options...
zebra Posted May 5, 2008 Share Posted May 5, 2008 Nah Ill Pull it out myself. Then Hopefully I can get the snapped stud out and Replace it. Link to comment https://www.sau.com.au/forums/topic/217724-clutch-pedal-gone-all-of-a-sudden-whilst-driving/#findComment-3844240 Share on other sites More sharing options...
Duncan Posted May 5, 2008 Share Posted May 5, 2008 yeah thats a pretty common point of failure. a few extra spot welds needed next time nissan Link to comment https://www.sau.com.au/forums/topic/217724-clutch-pedal-gone-all-of-a-sudden-whilst-driving/#findComment-3844697 Share on other sites More sharing options...
BLK33T Posted May 5, 2008 Author Share Posted May 5, 2008 the boyz just put a couple of weld down each side so it's not going to happen again ... good luck with it zebra ... Link to comment https://www.sau.com.au/forums/topic/217724-clutch-pedal-gone-all-of-a-sudden-whilst-driving/#findComment-3844896 Share on other sites More sharing options...
chiksluvit Posted May 5, 2008 Share Posted May 5, 2008 speaking of spot welds on the pedal brackets.. this reminded me that few days ago when my friend's r33 got broken into when parked on the streets in redfern/waterloo area nothing was stolen, all they did was they pulled the brackets out of the accelerator pedal and punctured one rear tyre.. when i saw it i was surprised how it didnt seem too hard to pull the bracket out... done with just a bit of leverage, force wasnt even enough to bend the bracket with clutch pedal being heavier than accelerator, especially if you have heavy duty clutch, i guess it'll become a weak point.. Link to comment https://www.sau.com.au/forums/topic/217724-clutch-pedal-gone-all-of-a-sudden-whilst-driving/#findComment-3845296 Share on other sites More sharing options...
BLK33T Posted May 6, 2008 Author Share Posted May 6, 2008 why would they pull the accelerator pedal box out? that is quite random! Link to comment https://www.sau.com.au/forums/topic/217724-clutch-pedal-gone-all-of-a-sudden-whilst-driving/#findComment-3845772 Share on other sites More sharing options...
chiksluvit Posted May 7, 2008 Share Posted May 7, 2008 why would they pull the accelerator pedal box out?that is quite random! ya it is and popped one of the tyres too the parking spots close to city, on the streets, in front of some houses.. they probably didnt like him parking there so decided to do something to his car so he won't park there whoever did it knew skylines quite well by the way it was broken into... Link to comment https://www.sau.com.au/forums/topic/217724-clutch-pedal-gone-all-of-a-sudden-whilst-driving/#findComment-3850624 Share on other sites More sharing options...
THENIG Posted May 8, 2008 Share Posted May 8, 2008 I Wish I had an easy fix like that Just Pulled my slave off to change as I thought it had gone only to find that the locating/pivot bolt for the clutch fork has snapped...Yay Gearbox has to come out now Same thing happened to my friend last weekend at DECA in Shepparton, had to drive it back to melbourne with no clutch starting it in gear. Do you know if there's anything that gets left inside the box that could be left dangling and doing damage to the inside of the gearbox?? Sorry don't mean to hijack thread.. Link to comment https://www.sau.com.au/forums/topic/217724-clutch-pedal-gone-all-of-a-sudden-whilst-driving/#findComment-3851108 Share on other sites More sharing options...
zebra Posted May 8, 2008 Share Posted May 8, 2008 I had a look...doesnt look like anything could do anydamage...the dust cover holds the clutch fork pretty tightly Link to comment https://www.sau.com.au/forums/topic/217724-clutch-pedal-gone-all-of-a-sudden-whilst-driving/#findComment-3851230 Share on other sites More sharing options...
