You want to drift like everyone else...just get a highflow...
Haha that's awesome i don't know if it was your intention but you make it sound like you frown upon all the wannabe drifters. If you are building your car for drifting tho i wouldnt reccomend a t04z even with the smallest housing. Unless you plan on pumping the shit out of your clutch drifting needs response and mid range torque to get the wheels spinning. Once there spinning it takes bugger all power at high rpm to keep them spinning.
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3866214
  • Replies 42
Lolz...glad to see someones picked up on it...
Back to the topic...like i said...if you want to drift like everyone else...don't even go the gt35...and 740cc injectors are overkill as well if you aren't pushing big numbers...
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3867597
Why go through all that trouble to change housings...even if it can be done...
You want to drift like everyone else...just get a highflow...it will make enough power and keep you happy...
hmmmm..... the thing is i dont want to make enough power.. i wanna make plenty of it... i have a t04e garrett on it now... and it should make around 250rwkw after injectors and so forth... but themax torque is at like 4600rpm... i found a place that u can buy the t04z for the same price with the exaust housings changed.... so therefor higher power...less lag.... things like camshafts should increase spool time and putting an rb30 bottom end... now im gettin out of my league...lol...
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3868015
ok... i didnt see the 2nd page to this lol..... ummm.... so if not a t04z recomended... what turbo is recommended...remembering that i do wanna make a nice sum of power..like 250rwkw +... im just really lost now.. the t04e is gay to drift with... i clutch kick the shite out of my car....and when it kicks in you almost go into a spin...lol...
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3868027
Highflow, best responce pumps out 250rwkw and your laughing
Will be able to pump about 280 out at max.. wack in cams, injectors fuel pump and a oil cooler for good measure and your laughing find a cheap one in the FS section and then get it checked out, new seals etc and ur ready for tyre spinning fun
Or you can buy a big ass turbo and wack in a tiny housing .. woot
Edited by DECIM8
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3868045
LOL.. hmmmm... ok... i think i have my set out in my mind.... gonna start looking at turboz but also 555cc injectors, tomei pon cams, adjustable cam gears, hicas lock bar, helll yyyyyyyyeeeeeeeaaaayyyyaaaaa
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3869459
Well its generally determined by cost.
GT35 = rebuild plus a lot of other stuff, 15k i reckon is a good number to match with 350rwkw.
GT-RS, bolt on, still within the motor limit and good response... less than half the GT35 route too
It wont look as flash though as its not a big donky cover like the t04e probably has on it (.7AR front), but will do the job a fair portion better.
More research as i said in another post.
T04Z is a 800-850HP turbo, bigger again than a GT35 (which i said a conservative 350rwkw).
Your talking 450rwkw+++ with a T04Z
I honestly thing you haven't taken anyones advice and researched.
If you simply put "T04Z" into the search feature you'd easily have worked out its an even sillier choice than the GT35
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3869471
ok!!!..... farkin hell... instead of me suggesting random turboz.... can sumone suggest a turbo for drift that will make a large number of power... i wanna see other opinions rather than my own...
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3871129
in my opinion i wouldnt do shit to ur 33 at all
id sell it and get and s15, if u want to drift do it a car that is made for drifting not the big boaty 33.
i sold my gtr and im looking for an s15 atm purely for drift, way cheaper to mod, newer and better car, imo
if u wanna really keep the 33 get a gt-rs turbo and some boost and that should do u some decent enough power. no point have haps of power with a to4z if it doesnt spool quickly, drift is all about response.
my 2c
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3871191
Have a look in the Dyno results thread.
Anything from 200-250rwkw will be the power aim, and then its upto YOU to decide how much response (or top end) you want from that particular turbo as they all have differing characteristics.
Its a pretty easy question, just read the Dyno/FI Guide stickies.
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3871362
dude!!!... ive already made my r33 to a pretty moded car...but now i just want it different.... no way i could sell it for an s15..... way to attached..its my first car and have only had it not even a year!!!...haha...although s15 do slide very nicely
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3871930
I haven't had any expereince with Wolf but ive been told they're not the best. I belive without a doubt Motec is by far the best and has great logging capabilites. I wish i had got one but atm i couldnt justify the money so i got a Haltech e11v2. I'm very happy with it still.
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3872049
motec is obviuosly the best but way too expensive for my liking.
who did u hear that wolf are not the best, one of my friends worked at rank rotary in melbourne before it got sold off and they specialised in them, i found them to be an awesome ecu and would recomend them to anyone.
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3872277
haha seriously, u need to do some more reading. on both turbo setups and drift, you do not need big power to drift, your placing way too much emphasis on power to drift, ur just feeding that stereotype or R33 drifters. if you want to drift, u need to focus on ur suspension, steering and diff before u worry about massive power. then u practice and u get better, 200rwkw is more than enough power to learn to drift.
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3872548
LOL.. i knew when i was reading this thread and Wolf got mentioned, Rank Rotary wouldnt be far behind.. :starwars: I also, from peoples experiences, would steer clear of Wolf.. and the no AFM setup doesnt help when you get EPA'd and the only check they do for ECU is unplugging the AFM to see if your car stalls.. :D (they may have revised these procedures since i was last there, but they thought they were pretty tricky dicky with this test)
Limpus - I was wondering the same thing.. Why hasnt ash come in here waving the 'search u kent' stick yet..? :D
https://www.sau.com.au/forums/topic/217830-power/page/2/#findComment-3877475
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
