my personal experience with them has not been that great. personally I think they are very overpriced for what they are. some people seem to love them though. for 30 man you could have either got something better imo or saved some money and gotten something just as good from another maker.
https://www.sau.com.au/forums/topic/217890-aragosta/#findComment-3849272
not many people make stagea specific parts
Im actually looking to track this car
i have some front and rear diffusers on the way
i have allt he supplies for full body undertrays and mounts, and many other aerodynamic goodies.
https://www.sau.com.au/forums/topic/217890-aragosta/#findComment-3849289
Sorry I kept you waiting for 2 days for a response, especially one that you knew was coming;
What so special about Stagea specific track springs and shocks?
Let's break it down to the individual components ;
Eibach make proper race quality coil springs in ID's from 50 mm to 75 mm, in rate increments of 25lbs/inch from 100 lbs/inch to over 3,000 lbs/inch. So you simply select the appropriate rate from that range, nothing Stagea specific there.
The top and bottom spring seats and the other coil over hardware are generic parts and a number of manufacturers (Bilstein, Koni, Eibach etc) have a range to suite the chosen spring diameters. Nothing Stagea specific there either.
The front shock body is dimensionally the same as R32/33/34 GTR, you simply select the valving to suite the spring rates you have chosen. Making sure it has a range of adjustment that covers all possible rate changes. Keeping in mind that the front swaybar is a spring as well and so it's rate has to be included in the damping requirement. Nothing Stagea specific in any of that.
The rear shock body is dimensionally the same as R33 GTST or R33GTR/R34GTT/R34GTR depending on which upright (hub) you are running. Once again you simply select the valving and adjustment to suite the range of spring rates you have chosen. As with the front, the rear swaybar rate has to be included in the damping requirement. Nothing Stagea specific in any of that either.
Keeping all of the above in mind, I can't see any need to suffer with an unsophisticated overpriced spring/shock combo as none of it is Stagea specific.
Cheers
Gary
https://www.sau.com.au/forums/topic/217890-aragosta/#findComment-3853254
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
