Just a quick question recently had engine built by sydney workshop. Had it a week & it blows white smoke only sometimes. Would it be because its just a fresh engine or would it be other circumstances to the problem. Has me slightly worried any ideas guys why this is. Cheers
https://www.sau.com.au/forums/topic/218097-new-engine/
one of your valve stem seals could be causing you a bit of trouble....maybe not sealing correctly because it was damaged when they incorrectly assembled the head last time....or damaged when repairs were being made to the valve train.
send it back and demand they fix it!
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3848302
Your not having much luck with this engine mate :P
If it were me, I would be taking it to another workshop and sending the original engine builder the bill for any repairs that are needed.
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3848322
Yeah no good blitz. Noluck me should have maybe gone somewhere else.
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3848358
your description of the problem is very general and not specific enough to necessarily indicate a problem. as you dont indicate when the smoke is seen (idle, under load etc?), it could be possible that the smoke your seeing is just a bit of richness added by your tuner for safety?
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3848498
ive seen the fuel and ignition map in this car....its definately not fuel related.
its white oil smoke 100%
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3848570
Was the engine correctly run in?
Idle it for any extended periods of time (more than 30 seconds) and you can bet your arse you will glaze those bores.
If it has been run in correctly, then you shouldn't have to worry about this.
Any chance you could be more specific on when the smoke is seen?
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3850314
Also, do not do as suggested and take it somewhere else and send in the bill to the previous workshop. You will not get one red cent out of them. The law states that a workshop MUST be given the opportunity to rectify the problem at their cost (if it's their fault), otherwise you will have no legal claim to monetary compensation.
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3850319
Mahle Pistons
Eagle Rods
Tomei cams 280
R33 crank grubbed
N1 block
Greddy oil pump
Tomei springs & buckets
Hks to4z
Hypertune Plenum
Sard 700cc inj
so it was just a freshen up then... lol
what about the head specifically, did they replace things like valve stem seals?
has it had a compression test and leak down test since the rebuild?
thats a piss off, after spending that much coin and still having problems.
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3851112
Your correct, however as I understand it the workshop in question has already had to rebuilt it for a second time due to valve train issues after the initial build.
https://www.sau.com.au/forums/topic/218097-new-engine/#findComment-3851116
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
