ok, so i have a hks2535..
do i keep on adjusting my boost via the adjustable actuator (will annoy me after a while) - i know its better to keep the wategate shut for as long as possible yada yada
or
lower actuator to lowest + install the turbo tech i got sitting here
or
lower actuator to lowest + be a wanker and have a cool hi/low switch for daily driving then 'spirited' (as u sau gents call it) driving?
winter is approaching, dont think i need 18psi to do wat i do, rather keep it low and give the thing a easier workload for a bit.
i already have all the above parts next to me, i just started my apprenticeship so things like profec b are not an option right now as id rather make-do with the above suggestions...
any ideas?
Edited by DjeMz
thats the thing, sick of feathering the throttle....
:thumbsup:
just dont mash it to the floor all the time.
I ran 24psi/350rwkw for ages, never really had a problem or needed to turn the boost down.
Even daily driving @ 270rwkw/17psi, 65-75% throttle = no problem easily.
Work with what you have...
Just use the turbotech to raise your boost to the desired level while using the adjustable actuator to control spiking or increase response...
I run the exact same setup with the same turbo on my rb20...works a treat...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
