Oh what?! I didn't read the link and thought this was an open day where most of the attendies would be from that club... I don't wanna 'compete' ... yet. Might come watch though.
Edited by sl33py
Competing is fun and means you get official timing :wave:
Clubs are usually very 'new member' friendly and I can protect you LOL
Its a sprint, like a time trial.
Hey BNR32t, if my car isn't ready, can you ask your sister if I can borrow hers, I'm sure she wont mind. And I promise I will return it dirty :)
You're not trying to hit on Keiths sister are you? hmmmmm??
Having a squiz at the regs it states " An extra bonnet restraint on vehicles with rear hinged bonnets." does that mean something like bonnet pins? or something else.
Having a serious think about this, will probably come along, need to sort out cams license first though.
No, I just figured if keith gave it a floging at the skid pan, and she didn't mind and I prob wont have a car....
Actually the car should prob be fixed, I just wont have enough money to put some tyres on it by then :)
i bought 2 tyres today from north west tyres on wollongong street in fyshwick today, cheap as, they were only 205/55/16 though but still $80 a tyre fitted
i've been thinking about this, cams licence cam back couple of days ago, hopefully water pump should be fixed soon...hopefully
Thats where I bought my rear tyres that I just destroyed from, I liked the bridgestones I bought from them before, but these were hopeless.
What tyre brand did you get?
Why weren't you at the texikhana anyways
Cos I went to Gosford and picked up a an engine and spent the day pulling the original one out. Plus I was on call with work, so hard to enter and then have to take off.
Sorry reece but the car has been in a crash...
PS. DONT TXTD N DRIVE. lol.
Anyone know of a 300z with a blown motor? :domokun:
Thinkin about going ot the next hill climb, Anyone else going?
Edited by BNR32t
Anyone know of a 300z with a blown motor? :stupid:
Woohoo 'bout time someone else joined Jeno, Jo and I at the hillclimb... next one is on the 25th May, having a break in June then having a 2 lapper in July.
C'mon Donnan, you should come to this one :domokun:
I'm hoping Ben and Alex will be there too.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
